The following C++ program does not compile
  • Context: C/C++
  • Thread starter Thread starter soul5
    C++ Program
The forum discussion centers on a C++ compilation issue related to outputting expressions using the stream insertion operator (<<). The incorrect syntax presented was count << "2 + 3 * 5 = " 2+3*5 << endl;, which fails to compile due to improper use of the operator. The correct approach is count << "2 + 3 * 5 = " << (2+3*5) << endl;, where the expression is properly enclosed in parentheses and separated by the insertion operator. This highlights the necessity of correctly formatting output statements in C++.
  • Understanding of C++ syntax and operators
  • Familiarity with the stream insertion operator (<<)
  • Basic knowledge of arithmetic expressions in C++
  • Experience with compiling C++ programs
  • Review C++ operator precedence and associativity
  • Learn about C++ output streams and formatting
  • Explore common C++ compilation errors and debugging techniques
  • Practice writing and compiling simple C++ programs
C++ developers, programming students, and anyone looking to improve their understanding of output syntax and compilation in C++.
soul5
do I just need to put it as
count << "2 + 3 * 5=" << (2+3*5) << endl;
Technology news on Phys.org
soul5 said:
count << "2 + 3 * 5 = " 2+3*5 << endl;do I just need to put it as
First one is bad, second one looks good.
Why don't you simply compile the second, run and test it? ooO, does the second one also throws error?
I'm pretty sure you can't mix string output together with variables. You must separate them into with <<.
  • · Replies 23 ·
13K
