Work to push a sled up a hill: Friction, inclines,force,work
The discussion focuses on calculating the work done in pushing a sled up a 15-degree incline with a mass of 35 kg and a coefficient of kinetic friction of 0.2. The normal force is calculated as 331.313 N, while the downhill gravitational force is 88.77 N, resulting in a friction force of 66.262 N. The total uphill push force required to maintain constant velocity is 155.038 N, leading to an initial work calculation of 2156 J. However, adjustments for the horizontal push yield a revised work estimate of 2232 J, which is still lower than the back-of-the-book answer of 2300 J.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of friction and normal force
  • Knowledge of trigonometric functions in physics
  • Ability to apply work-energy principles
  • Study the effects of inclined planes on force calculations
  • Learn about the work-energy theorem in physics
  • Explore the role of friction in motion on inclines
  • Investigate how to calculate work done with varying angles of force application
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of applied physics concepts in real-world scenarios.
krausr79
We are pushing a sled up a hill. Our push is horizontal. The hill is inclined at 15 degrees. The sled masses 35 kg. The coefficient of kinetic friction is .2. The hills height is 3.6 m. We push at a constant velocity. How much work do we do in pushing?
Mass*Gravity Accel*cos(15) = Normal force/Gravity into surface
Mass*Gravity Accel*sin(15) = Gravity slideways
Normal*Coef of friction = friction force
sin(x) = Opp/hyp or hyp = Opp/sin(x)
Work = Force*Distance
Normal force = 35*9.8*cos(15) = 331.313N
Force down hill = 35*9.8*sin(15) = 88.77N
Friction force = 331.313*.2 = 66.262N
Length of incline = 3.6*sin(15) = 13.909M
With constant velocity, forces will equal out
gravity and friction = uphill push force = 66.262+88.77 = 155.038N
Work = 155.038*13.909 = 2156J ?
I thought this would be it assuming the force and distance must be in the same direction.
forward push*cos(15) = uphill push
forward push = Uphill push/cos(15) = 155.038/cos(15) = 160.507
Work = 160.507*13.909 = 2232J ?
The back of book answer is 2300J (2 significant digits)
Where is the error?
Hi krausr79! :smile:
No, the push is horizontal, so that will add to the usual normal force. :wink:
Thank you.
13K
