Understanding Voltage Dividers to Redrawing and Solving Ladder Networks
This discussion focuses on solving ladder networks using voltage dividers, specifically in the context of a circuit with resistors of 8 ohms, 24 ohms, 20 ohms, and 40 ohms. Participants emphasize the importance of determining equivalent resistance and applying Ohm's Law to find the voltage across specific resistors. The process involves redrawing the circuit as a series of voltage dividers and calculating voltages at various nodes. The Electrician and other contributors provide guidance on how to approach the problem methodically.
  • Understanding of voltage dividers and their applications
  • Familiarity with Ohm's Law
  • Basic knowledge of series and parallel resistor combinations
  • Ability to interpret circuit diagrams
  • Study the principles of voltage dividers in detail
  • Learn how to calculate equivalent resistance in series and parallel circuits
  • Practice solving ladder networks with varying resistor values
  • Explore additional resources on circuit analysis techniques
Electrical engineering students, circuit designers, and anyone looking to enhance their understanding of voltage dividers and ladder networks in electrical circuits.
qwerty321
Hello
I have the figure below,and i do not understand the question..It says:
Determine V0 by redrawing the ladder network above as a cascade of three voltage dividers...can someone explain to me what to do?
thank you!
ok like using ohm's law,so can anyone help me solev this circuit?
Can you show an example of what your text shows as a voltage divider?
i didn't understand what you mean?
the picture is attached..and by the way,the electrician, thansk for always helping me:d
you determine the equivalent resistance of everything except the 8 ohm resistor. then you use a voltage divider to determine the voltage across this equivalent resistance.
then you use a similar process to determine the voltage at the node where the 24, 20, and 40 ohm resistors connect. then finding V0 should be trivial.
In another post you said you were studying for CCE. What is that? Is it a course, or is it a study guide for a test of some sort.
Don't you have course materials that explain what a voltage divider is? Is there a picture (schematic diagram) of a single voltage divider? If there is, post an image of it here.
umm cce means computer and communications engineerig at university..i have a course named electric circuits and signals..
And do you have a textbook (or other written material) for this course?
What The Electrician is getting at is: your book (or other written material) would be a good place to look up what a voltage divider is ... or any other term that comes up in your homework problems.
can someone post the solution, i know its an old post but now i need the answer:) i have the same question in my year.. I am studying cce too ! can someone help?
did you try to work through the suggestion in post 6 ?
you'll see, this stuff is real easy. but you've actually got to work through a few.
You need to start at the right of the diagram.
There are two resistors in series. What is their total resistance?
These are in parallel with another R. What is the combined resistance?
Now, this combination is in series with another resistor, so what is the combined resistance?
You go from right to left keeping a note of all these combinations.
If you have two resistors R1 and R2 in series with 100 volts across them, the voltage across R2 will be...100 times R2 / (R1 + R2 ) .
Now, you move from left to right starting with the supply voltage. What is the voltage at the junction of the first two resistors knowing the equivalent resistance to the right of that point?
Then move to the next junction and so on.
  • · Replies 35 ·
