Joint Bivariate Exponential Distribution
The discussion focuses on the joint bivariate exponential distribution of two components subjected to three types of independent exponential shocks, characterized by rates \(\lambda_1\), \(\lambda_2\), and \(\lambda_3\). The problem requires calculating the probability \(P\{X_1 > s, X_2 > t\}\), where \(X_1\) and \(X_2\) represent the failure times of components 1 and 2, respectively. The presence of type 3 shocks complicates the independence of \(X_1\) and \(X_2\). References to the works of Yan, Carpenter, and Diawara (2006) and Diawara and Carpenter (2008) provide foundational insights for solving this problem.
  • Understanding of joint bivariate exponential distributions
  • Knowledge of independent exponential random variables
  • Familiarity with probability theory and calculations
  • Access to research papers in applied mathematics
  • Review the joint distribution of independent exponential random variables
  • Study the papers by Yan, Carpenter, and Diawara (2006) and Diawara and Carpenter (2008)
  • Learn about calculating probabilities in bivariate distributions
  • Explore applications of exponential distributions in reliability engineering
Students and researchers in statistics, applied mathematics, and reliability engineering who are working with joint distributions and exponential random variables.
e(ho0n3
Consider two components and three types of shocks. A type 1 shock causes component 1 to fail, a type 2 shock causes component 2 to fail, and a type 3 shock causes both components 1 and 2 to fail. The times until shocks 1, 2, and 3 occur are independent exponential random variables with respective rates [itex]\lambda_1, \lambda_2, \lambda_3[/itex]. Let [itex]X_i[/itex] denote the time at which component i fails, i = 1, 2. The random variables [itex]X_1, X_2[/itex] are said to have a joint bivariate exponential distribution. Find [itex]P\{X_1 > s, X_2 > t\}[/itex].
The attempt at a solution
This problem would by so much easier if type 3 shocks didn't exists as it would make [itex]X_1, X_2[/itex] independent. Anywho...
Let [itex]Y_1, Y_2, Y_3[/itex] be the times shocks of type 1, 2, 3 occurred. I know I'm going to have to deal with the joint distribution of these three random variables. However, I can't think of anything. I need a little hint.
One idea is suggested in Yan, Carpenter and Diawara (2006) and in Diawara and Carpenter (2008) in their papers from AJMMS. Please check it out, and let me know if you have questions.
