How much effort do you think it would take to make your own card access system?
  • Thread starter Thread starter Disowned
    System
The discussion revolves around the feasibility and effort required to create a custom card access system, focusing on the components needed, potential designs, and operational methods. The scope includes theoretical considerations, technical explanations, and practical challenges related to hardware integration.
  • One participant suggests that parts for a magnetic reader can be acquired for $40 to $60 and theorizes about connecting it to a keyboard for a card access system.
  • Another participant questions the rationale behind connecting the reader to a keyboard instead of using a USB connection to a PC with a custom program.
  • A participant proposes a standalone system where the lock operates independently of a PC, involving a card reader, monitor, and keyboard, but expresses concerns about the feasibility due to time and financial constraints.
  • It is mentioned that barcode readers can connect to keyboard ports and send key scan codes, suggesting that a card reader could potentially function similarly, although signaling back to the lock remains a challenge.
Participants express differing views on the best method to connect the card reader and the overall design of the access system. There is no consensus on the optimal approach or the practicality of the proposed systems.
Participants have not fully explored the technical requirements for signaling the lock mechanism, and there are unresolved questions about the integration of components and the feasibility of a standalone system.
Individuals interested in DIY electronics, security systems, or those exploring custom hardware projects may find this discussion relevant.
Disowned
I know you can get the parts to make a magnetic reader for around 40 to 60 dollars. I also know (from reading 2600 mag) that you can access the magnetic strip of your credit card and rewrite the data inside it. I think it is possible to get the magnetic reader to communicate with your keyboard if you solder them together. Given this, it is possible to make a security card access system to something like a door?
Disowned, what the hell do you mean by card access system?
Well, I mean is basically a security that revolves around your card as the key to unlock that system. Maybe I'm not explaining it correctly but someone out there has to know what I am talking about.
Computer science news on Phys.org
Why would you connect the reader to your keyword? Not USB to your PC with custom program?
Well I theorizing a system that could operate without interaction from the PC. A standalone program, if you will, where the lock system would be operated by the card reader, a monitor, and the keyboard.
However, given what you said, it would much easier to do this if I took an old RTV unit and PC and hooked it up to the reader and keyboard. Not that I have the money or time to embark on this project anyway.
Bar code readers connect to the keyboard port and send the key scan codes as if you had typed on the numeric keypad - I suppose a card key could do the same. The advantage of this is that you don't need to change the software.
But you would need someway of signalling back to the lock wether or not it should open.
  • · Replies 18 ·
14K
  • · Replies 16 ·
