Estimating ΔA of Triangle When Side Shrinks 0.2 cm
  • Thread starter Thread starter clairez93
    Differential
The discussion focuses on estimating the change in area (ΔA) of an equilateral triangle when its side length decreases from 10 cm to 9.8 cm. The area is calculated using the formula A = (1/2) * base * height, with the height derived from the side length. The final computed change in area is approximately -1.732 cm², indicating a decrease in area due to the reduction in side length. The conversation highlights the importance of simplifying expressions for easier calculations.
  • Understanding of calculus, specifically differentiation.
  • Familiarity with the properties of equilateral triangles.
  • Knowledge of the area formula for triangles, A = (1/2) * base * height.
  • Ability to manipulate and simplify algebraic expressions.
  • Study the differentiation of geometric functions in calculus.
  • Learn about the implications of small changes in dimensions on area and volume.
  • Explore the concept of linear approximation in calculus.
  • Review the properties and formulas related to equilateral triangles.
Students studying calculus, geometry enthusiasts, and anyone interested in understanding the effects of dimensional changes on geometric figures.
clairez93
A side of an equilateral triangle is measured to be 10 cm. Estimate the change in the area of the triangle when the side shrinks to 9.8 cm.
[tex]A = 1/2*bh[/tex]
[tex]x = 10, dx = 0.2[/tex]
[tex]b = x/2, h = \sqrt{x^{2} - x^{2}/4}[/tex]
[tex]1/2(x/2)(\sqrt{3x^{2}/4} = \sqrt{3x^{2}}b / 8[/tex]
[tex]dy = f'(x)dx = f'(10)(-0.2)[/tex]
[tex]f'(x) = 8[(3x^{1/2})^{1/2} + 1/2(3x^{2})^{-1/2})(6b)(b)] / 64[/tex]
[tex]= 8(\sqrt{3x^{2}} + 3x^{2} / \sqrt{3x^{2}) / 64[/tex]
[tex]= 8(6x^{2} / \sqrt{3x^{2}}) / 64 = 48x^{2}/\sqrt{3x^{2}} / 64 = 48x^{2} / 64\sqrt{3x^{2}}[/tex]
[tex]dy = (48(10)^{2} / 64\sqrt{3(10)^{2}})(-0.2) = -0.866[/tex]
[tex]Delta A = f(x + Delta x) - f(x)[/tex]
[tex]= f(10-0.2) - f(10)[/tex]
[tex]= f(9.8) - f(10)[/tex]
[tex]= 20.793 - 21.651[/tex]
[tex]= -.857[/tex]
Answer Key: -1.732
You seem to be using 'b' to mean both the base of the triangle (which is actually x), and the base of right triangle you get by splitting the equilateral triangle in two. You should have gotten that the area is A=(1/2)*x*sqrt(3x^2/4). For future reference, you can make life a lot easier if you simplify expressions before proceeding onwards. Like you could simplify the area to A=sqrt(3)*x^2/4. Doesn't that make it easier?
