Proof by Induction: P(k) to P(k+1)
  • Thread starter Thread starter kathrynag
    Induction Proof
The discussion revolves around proving the inequality (1+x)^{k} ≥ 1+kx using mathematical induction, specifically transitioning from P(k) to P(k+1). Participants are exploring the implications of this inequality and its validity under certain conditions.
  • Participants discuss how to utilize the established inequality (1+x)^{k} ≥ 1+kx to derive the next step for (1+x)^{k+1}. There is uncertainty about how to correctly expand and manipulate the expressions involved.
Some participants have offered insights into the implications of multiplying inequalities and the need to consider the sign of the terms involved. There is an ongoing exploration of the conditions under which the original inequality holds, particularly regarding the value of x.
Participants note the lack of restrictions on x, while others suggest that certain assumptions may need to be made, such as requiring 1+x > 0. There is a discussion about the implications of specific values of k and x on the validity of the inequality.
kathrynag
[tex](1+x)^{k}[/tex][tex]\geq[/tex]1+kx
I want to show for P(k+1)
(1+x)^(k+1)[tex]\geq[/tex]1+kx+x
(1+x)^k*(1+x)[tex]\geq[/tex]1+kx+x
Use this:
I don't really understand how I use that...
You want to use an inequality involving [tex](1 + x)^k[/tex] to derive an inequality involving [tex](1+x)^k (1+x)[/tex], which is a multiple of it.
An inequality still holds if you multiply both sides by a positive number. If you multiply both sides of an inequality by a negative number, then you have to flip the sign from [tex]\le[/tex] to [tex]\ge[/tex] or vice versa.
Ok, so:
(1+x)^k(1+x)>(1+kx)(1+x)
>(1+2kx+x)
Right idea, but there is an error in your expansion.
Does the question give any restrictions on x? Is what you wrote still true of 1 + x < 0?
No restrictions.
1+kx+x+kx^2
When k = 3 and x = -4,
[tex](1 + x)^k = (-3)^3 = -27 < -11 = 1 - 12 = 1 + kx[/tex]
which makes the statement false.
So, we have to assume 1+x>0
so, x>-1
I believe x has to be strictly within 1 unit of 1; i.e., |1 + x| < 1, which means that 0 < x < 2.
kathrynag said:
No restrictions.
1+kx+x+kx^2
Once I get here I'm unsure where to go
Look at your first post; you need to show that that is [tex]\ge 1 + kx + x[/tex].
  • · Replies 23 ·
