Solidworks Modeling Help: Geodesic Dome Pentagons, Hexagons, Struts
  • Thread starter Thread starter Byron C
    Model Solidworks
The discussion revolves around modeling a geodesic dome in SolidWorks, specifically focusing on the alignment and sizing of pentagons, hexagons, and struts. Participants explore various modeling techniques and constraints within the software, addressing issues related to component alignment and assembly.
  • Experimental/applied
  • The original poster (OP) describes difficulties with a strut that does not align properly between two pentagons in their geodesic dome model.
  • One participant suggests creating separate "rings" for the components and using constraints in assembly to ensure proper alignment, rather than specifying angles directly.
  • A moderator raises the possibility of referring the OP to another forum for additional help, mentioning a known issue in SolidWorks that may affect the assembly process.
  • Another participant requests more detailed information about the OP's modeling process, asking about the methods used for sketching and constraints applied to the drawing.
  • The OP provides a detailed account of their modeling process, including the creation of pentagons and struts, and the assembly steps taken, while noting the misalignment issue with the final strut.
Participants express varying approaches to modeling in SolidWorks, with no consensus on the best method to resolve the OP's alignment issue. The discussion remains unresolved as multiple perspectives on modeling techniques are presented.
Limitations include potential missing assumptions about the modeling process, the specific constraints applied, and the software's behavior that may affect the assembly of components.
Byron C
I am new to modeling and am trying to draw a geodesic dome consiting of pentagons with 30degree stuts at each point forming a hexagon. The final strut joining the 2 pentagons is not lining up and is too short. Everything is equal and symetrical. What is going on? Should they line up?
I'm not 100% familiar with solidworks, but are you actually placing the struts, etc? My attempt would be to create the "rings" separately. Then (in Unigraphics) I would bring them in each as a different components in am assembly. From there rather than specifying a position/angle, you can simply give the edges and points constraints. So, rather than edge 10 being connected to point 56 at a 15.223634532°, its just connected to these points. It should force the angles and everything by itself if you constrain it properly.
at least that's what I would try to do.
Moderators,
Am I permitted to refer the OP to another forum? I'm not in any way promoting the site I would refer him to, but this is close to a world class problem due to a bug/quirk/interesting feature in SolidWorks which causes loss of mates in problems like this.
I know how to do this using the "use a larger hammer" method, but I think the OP really wants a more elegant solution than that. Some of the User Group gurus have dealt with this and should be able to help him.
You're going to have to be more descriptive as to how you are doing this? Are you importing coordinates, working off a 3D sketch, sketch/extruding as you go? Place some measurement constraints on the drawing to see if the numbers at least match up.
I am drawing the pentagon (Yellow) on the front plane with sketched lines, the sketch is symmetrical about the Y axis and the top point of the pentagon is at the origin. I then draw a circle on the right plane at the top point of the pentagon (at the origin) and extrude the circle on a sweep to form the round bar pentagon. I then create a 30 degree plane from the top plane through the origin on the top corner point of the sketched pentagon and draw circle on that plane and extrude it to form the short strut(Blue) at 30 degrees. I then mirror the short struts to the other corners of the pentagon. In a new part I then create my long strut(Pink) with a circle and extrude it. I then create an assembly with the pentagon and insert the long strut mating it coincident and concentric to the short strut. I then insert a duplicate of the pentagon and mate it the same way to the other end of the long strut. Then repeat the insert long struts and pentagons and mating process. The final strut that joins the 2 inserted pentagons is not lining up and too short as seen in the pic.
10K
10K
  • · Replies 27 ·
11K
  • · Replies 21 ·
  • · Replies 0 ·
