Calculating charge on a capacitor in a DC circuit
The charge on a capacitor in a DC circuit can be calculated using the formula Q_C = C ΔV, where C is the capacitance and ΔV is the potential difference across the capacitor. In this discussion, the potential difference was determined to be 2 V, resulting in a charge of 20 nC for a capacitor with a capacitance of 0.01 μF. The steady state condition indicates that the capacitor behaves as an open circuit, allowing for the calculation of voltage using a potential divider with a 10 V battery and two equal resistors. The final charge calculation is derived from the established voltage difference across the capacitor terminals.
  • Understanding of capacitor charging in DC circuits
  • Knowledge of Ohm's Law and voltage division
  • Familiarity with the concept of steady state in electrical circuits
  • Basic proficiency in using formulas for charge and capacitance
  • Study the principles of capacitor behavior in DC circuits
  • Learn about potential dividers and their applications in circuit analysis
  • Explore the effects of different capacitance values on charge calculations
  • Investigate transient analysis in RC circuits for a deeper understanding
Students studying electrical engineering, circuit designers, and anyone interested in understanding capacitor behavior in DC circuits.
dancavallaro
See attached image for a circuit diagram. The assumptions are that transients have died out and the currents and charges have reached their equilibrium values. I have to calculate the charge on the capacitor.
[tex]Q_C = C \Delta V[/tex]
[tex]V_C(t) = Q(t)/C = V_0(1-e^{-t/RC})[/tex]
I honestly am not really sure where to start with this. Given the formula above, it's clear that I need to calculate the voltage across the capacitor. But I only know how to calculate the voltage across something with a known resistance, using Ohm's Law. I guess my first question would be, how can I calculate the voltage across a capacitor? And once I have that, I can just use [tex]Q_C = C \Delta V[/tex] to calculate the charge.
edit: nevermind, I figured this out on my own.
The idea is to find the potential difference across the capacitor. From that the charge on it can be found.
At steady state there will be no current flowing to or from the capacitor; it is effectively an open circuit. So remove the capacitor from the circuit and determine the potential across the points where it was connected. This is easily done if we find them with respect to the reference node.
On the left we have a potential divider comprising a 10 V battery and two equal resistors. So the potential at their junction will be half the battery voltage, or 5 V. On the right side there is a battery in series with a resistor. Since there's no current flowing ("open" capacitor), there's no potential change across the resistor. So the potential at that capacitor terminal is equal to that battery voltage, or 3 V.
The capacitor "sees" the difference between those potentials, or 2 V. So the charge on the capacitor is, given by Q = CV, is
##Q = (0.01~μF)(2~V) = 20~nC##
  • · Replies 30 ·
