Learn Hyperbolic Geometry: Why & How Does Parallelism Work?
  • Context: Graduate
  • Thread starter Thread starter kexue
    Geometry Hyperbolic
The discussion focuses on the concepts of hyperbolic geometry, particularly the nature of parallel lines in the hyperbolic plane and the interpretation of the boundary of the hyperbolic plane. Participants explore different models of hyperbolic geometry, including the upper half-plane and the unit disc, and their implications for understanding parallelism and boundaries.
  • One participant describes the hyperbolic plane using the upper half-plane model and questions why there are infinitely many hyperbolic lines parallel to a given line L through a point not on L.
  • Another participant suggests that parallel lines in hyperbolic geometry may simply mean that two lines do not intersect.
  • A participant proposes that hyperbolic geometry might be better understood using the unit disc model, where classical Moebius transformations serve as isometries, asserting that this perspective clarifies the existence of infinitely many parallels.
  • Another participant agrees with the unit disc model, stating that the boundary of the unit disc is the unit circle, which can be mapped to the real line plus a point at infinity on the Riemann sphere, suggesting this mapping aids in understanding the boundary concept.
Participants express differing views on the best model for studying hyperbolic geometry and the interpretation of parallel lines. There is no consensus on the definitions or implications of these concepts, indicating ongoing debate and exploration.
Some participants note that the understanding of parallel lines and the boundary of the hyperbolic plane may depend on the chosen model (upper half-plane vs. unit disc), highlighting potential limitations in definitions and interpretations.
kexue
I like to learn some basic hyperbolic geometry!
Starting with the hyperbolic plane, the upper half plane with the hyperbolic lines being all half-lines perpendicular to the x-axis, together with all semi-circles with center on the x-axis.
Why and how are there always infinitely many hyperbolic lines parallel to a given hyperbolic line L and passing through a given point p not lying on L?
Does parallel in hyperbolic geometry just mean two lines do not cut each other?
Second problem.
My book says the boundary of the hyperbolic plane can be thought of as real line [tex]\cup[/tex] infinity, which is supposed to be a circle. I can't see this to be a circle. What does the author mean?
thank you
Second problem.
thank you
In my opinion hyperbolic geometry is best studied at first on the unit disc where classical Moebuis tranformations of the complex plane that preserve the disc are isometries. It is immediate from this way of looking at it that there are infinitely many parallels to a line through any point.
For the upper half plane, it is good to map it onto the disc conformally and take the induced metric.
Second problem.
thank you
On the unit disc the boudary is the unti circle, no problem here. This circle is mapped to the real line plus the point at infinity on the Riemann sphere by a conformal mapping of the unit disc onto the upper half plane. I urge you to learn it this way.
  • · Replies 36 ·
9K
  • Poll Poll
  • · Replies 44 ·
26K
