Measuring Engine Torque with Alternative Fuels | How-To Guide
The discussion revolves around measuring engine torque using alternative fuels, specifically biodiesels, without access to a dynamometer. Participants explore methods to estimate torque based on available equipment and propose various approaches to assess engine performance with different fuels.
  • Experimental/applied
  • One participant seeks methods to measure engine torque without a dynamometer, suggesting calculations based on horsepower and acceleration.
  • Another participant emphasizes the necessity of a dynamometer for accurate torque measurements and suggests using a torque transducer with a flywheel to measure angular acceleration.
  • A third participant questions the validity of calculating peak torque from peak horsepower without practical measurements and mentions the potential complications of turbocharged engines.
  • Concerns are raised about the variability of fuel combustion models and the challenges in simulating accurate performance data.
  • One participant proposes timing the engine's acceleration from idle to peak RPM as an alternative method to gauge fuel performance, suggesting the addition of a load on the flywheel for better measurements.
  • A suggestion is made to build a DIY dynamometer using a heavy flywheel and a braking mechanism to measure torque under load, with recommendations to repeat measurements at various RPMs.
  • A later reply indicates that an "inertia dyno" concept aligns with the participant's approach, potentially simplifying the measurement process without needing additional load beyond the flywheel's weight.
Participants generally agree on the challenges of measuring torque without a dynamometer and the importance of practical data. However, there are differing views on the feasibility of alternative methods, and no consensus is reached on the best approach to measure torque accurately.
Participants express uncertainty regarding the accuracy of calculations based on horsepower and the limitations of using handheld tachometers. The discussion highlights the dependence on practical setups and the challenges posed by varying fuel types.
This discussion may be useful for individuals interested in engine performance measurement, alternative fuel applications, and DIY experimental setups in automotive engineering.
eoe
i've got an engine to work with, and i have the basic specs of it like peak hp @ an rpm. but, i don't have figures for torque. I need to know how i can measure the torque of the engine with different fuels. I calculated the torque of the engine from their hp figure, but I'm having trouble figuring out a way i can measure the torque once i put in various types of fuels (biodiesels).
the engine won't be in a vehicle, and i don't have access to a dyno. i know its possible to calculate torque from acceleration, speed, and time, but i can't seem to find it/figure it out.
thanks in advance
Your going to need a dyno if you want to do any meaningful measurements. Without putting a load on the engine there is just no way that you can accurately compare performance of different fuels or even take any actual torque measurements.
The only way I can think of doing is to connect the output shaft to an oversize flywheel in a torque transducer in between. Throttle up the engine and record the angular acceleration.
I don't even know how you have calculated peak torque from the peak horsepower figure. You definitely need some driven equipment (preferably a dyno) to measure torque. A heavy flywheel might give you a pretty good estimate unless the engine is turbocharged (which, given that you're talking about biodiesels, is a definite possibility).
You can't do it eoe, not without practical data.
Fuel is the worst possible variable as an accurate combustion model is incredibly difficult to find for simulations and requires vigorous validation.
i calculated the torque from looking at the formula for power. and i used the engine's measured stroke as the distance, but now I'm thinking that doesn't really work? all i'll have is a hand held tachometer (with a laser) that i will measure off the flywheel. and the engine isn't turbo'd, its a small engine rated at 6.5hp. If i can't measure torque, i can just think of another way to determine which fuel will let the engine be more powerful.
would it work if i were to time how fast it takes the engine to go from idle rpm to peak rpm (3600) with each fuel? I think i'd have to bolt something on the flywheel to put the engine under load in order to time it better.
thanks for the replies
Time to get building your own dyno then. A cheap and cheerful option would be to use a heavy flywheel and brake it somehow with a known amount of force. This will give the engine a load and you can measure the rpm drop, an engine with higher torque output will keep the flywheel spinning at a constant rate under a higher load.
You will nead to repeat this at several different rpm to get an indiation of the variation of torque. Also be sure to note the rpm fluctuations as you will also have some indication of the cyclic variation.
Edit found this site, not read it all but it looks useful: http://www.dyno-dynamometer.com/how_dyno_works.htm
thanks chris, that site is extremely useful. I think I've got it figured out now. it has a part about an "intertia dyno" which is just like what i was describing, so i won't need to provide a load for on the flywheel besides its own weight. i really appreciate all the help
  • · Replies 18 ·
  • · Replies 22 ·
9K
  • · Replies 18 ·
  • · Replies 39 ·
