Solve for Four Numbers: Sum and Product = 711
  • Context: Undergrad
  • Thread starter Thread starter ultimablah
The discussion revolves around finding four numbers whose sum and product both equal 711. Participants explore the implications of the problem, including the nature of the numbers (integers vs. real numbers) and the mathematical relationships involved.
  • One participant notes that there are two equations with four unknowns, suggesting brute force may be necessary and questioning if there is a special circumstance.
  • Another participant points out the prime decomposition of 711 and suggests that there are limited combinations of integers that could satisfy both equations, but finds none that work.
  • A third participant highlights that the term "numbers" could imply non-integers, which may change the approach to the problem.
  • One participant proposes a method involving assumptions about the numbers, leading to a derived solution that includes both positive and negative values.
  • Another participant agrees that there are infinitely many solutions, referencing the equations and providing a method to demonstrate this through a quadratic equation.
  • Some participants discuss the implications of adding additional equations and the nature of the original equations, with one admitting to an error in their earlier assessment of the number of equations.
  • A participant mentions a similar problem referred to as the "7-11 Problem," suggesting that their teacher claimed there was only one solution, but expresses skepticism about this assertion.
Participants generally agree that there are infinitely many solutions to the problem, but there is disagreement regarding the nature of the numbers involved and the validity of certain approaches. The discussion remains unresolved regarding the implications of the problem's structure.
Participants express uncertainty regarding the assumptions made about the types of numbers (integers vs. real numbers) and the implications of the equations being non-linear. There are also unresolved mathematical steps in the proposed solutions.
ultimablah
The sum of four numbers equals the product of four numbers equals 711.
What are the four numbers?
I see 2 equations with 4 unknowns, and no way to do this but brute force it; is there a special circumstance here?
Mathematics news on Phys.org
The sum and product of the same 4 numbers are equal to 711? Is that what you mean?
The prime decomposition of 711 is 3^2*79. There aren't too many ways to get 4 numbers; you either have 1, 1, 9, 79, or 1, 1, 3, 237 or 1, 3 , 3, 79. None of those sum up to 711. Can you restate the problem more clearly?
Admittedly, he did say "numbers" and not "integers", so the prime factorization of 711 isn't necessarily relevant, although I agree it's certainly implied. Hmm...
DaveE
Hm...Just thinking out loud here. This approach requires making certain assumptions that could prove to be wrong. Please forgive my formatting errors.
711 = a+b+c+d
711 = abcd
The first two assumptions are that a = 711, so:
0 = b+c+d
1 = bcd
The next one is that bc = 1, which means that
d = -1
and
-1 = bc
and that
-1/b = c
which means that
711 = 711-1+(-1/b)+b
0 = -1-(1/b)+b
0 = b^2-b-1
b = [1+-(1-4*-1*1)^1/2]/2
b = [1+-(5)^1/2]/2
b = 1.618 or -.618
Therefore, since -1/b = c
When b = 1.618, c = -.618 and when b = -.618 c = 1.618
And that since addition and multiplication are communicative, one of these solution is redundant.
So, in conclusion (finally :smile:)
Since -1 = bc
711 ?= 711*-1*-1
711 = 711
and
711 ?= 711-1-.618+1.618
711= 711
a = 711
b = -.618
c = 1.618
d = -1
Q.E.D.
As the op said, these are two equations in 4 unknowns. There are infinitely many solutions. F(x) has added 3 more equations which seems extravagant under the circumstances.
Haha. Nevertheless, those three extravagant equations allowed me to find one possible solution.
Oh, and by the way, prove that there are a infinite number of solutions.
That's pretty easy, no?
w+x+y+z = 711
wxyz = 711
w = 711/xyz
Assume z=1:
w=711/xy
711/xy+x+y+1 = 711
711 + x^2y + xy^2 = 710xy
xy^2+(x^2-710x)y+711 = 0
You can use the quadratic formula (though it's messy) to solve for y, with:
A = x
B = x^2-710x
C = 711
So as long as 2A =/= 0, and B^2 > 4AC, you're good. Specifically:
x =/=0
x^4+2x^2-1420x+504100x^2 > 2840x
x^3+2x+504100x > 4260
So, without bothering to solve it, it's obvious that for x>1, the quadratic will be solvable, because it'll satisfy the above requirements. And obviously there are an infinite number of values for x>1.
DaveE
My bad. f(x) only added two equations, the expected number. As not both of the original equations are linear it is not enough to merely count equations and unknowns as I did. However, davee123 has saved the day for me on this point.
Haha fine. I'm too tired to look through your post right now, so I'll just agree for the moment.
Just as a side note, my math teacher has a problem that is exactly similar to this one that that he calls the "7-11 Problem" (as in the gas station). When asked, he said that there was only 1 possible solution to this, and I am tempted to agree because the problem combines addition and multiplication. But, he is not infallible.
  • · Replies 68 ·
14K
