Coefficient of rolling friction question
The discussion revolves around measuring the coefficient of rolling friction between car tires and a road surface, specifically examining how different air pressures in the tires may affect this measurement. Participants are considering a procedure that involves sliding a mass and timing its stopping distance to infer frictional properties.
  • Participants explore how varying tire pressure might influence stopping distances and acceleration. Questions arise about the relationship between pressure, weight, and friction. Some express uncertainty about the equations needed to relate distance, velocity, and acceleration to the coefficient of friction.
There is an ongoing exploration of the theoretical underpinnings of the problem, with participants sharing insights and questioning assumptions. Some guidance has been offered regarding the use of kinematic equations, but no consensus on a specific approach has been reached.
Participants note the complexity of measuring time accurately and the implications of using different methods to calculate acceleration and friction. The discussion acknowledges the need for clarity on how pressure affects the physical properties being measured.
Draggu
Describe how you could use the procedure from this experiment to measure the coefficient of rolling friction between the tires of a car and the road surface for different pressures of air in the tires?
Procedure =
1. Slide a mass along the surface of a lab desk and release the mass at a preselected "starting point"
2. Use a stopwatch and record time/dist taken for the mass to come to a complete stop.
I really have no idea. Any hints would be nice :(
Procedure =
All things being equal, if different pressures produce different stopping distances what can you say about acceleration? And if there are different accelerations - that would be due to what?
Err, the car tires with more pressure will accelerate faster than the one's with less pressure.
Hi Draggu! :smile:
Assume it's the same as ordinary friction …
what equation relates the stopping distance (from a particular speed) to the coefficient of friction?
Well, I read the question over and over and I guess it's trying to say that if we put more/less pressure in the car, it can help measure the coefficient of friction?? If the tires have more pressure they weigh more (more air) but they also would roll faster than tires with less pressure, and less weight. But! Newtons law states that Force= mass* acceleration
Or, Force of Friction = coefficient of friction * mass * gravity
I just don't get it! and I have no idea what equation relates to that, tiny-tim. I'm just crappy at physics I guess
Draggu said:
… I guess it's trying to say that if we put more/less pressure in the car, it can help measure the coefficient of friction??
Perhaps I'm missing the point :redface:,
but I don't think they're asking you to theorise about how the pressure affects it …
just to measure the effect :wink:
So long as you are keeping in mind greater acceleration here means less deceleration. What you are measuring of course is negative acceleration - i.e the slowing down kind of acceleration. Firmer tires will roll longer yes? (Consider the extreme case of flat tires for instance.)
From kinematics then you can determine what each distance means wrt the slowing deceleration and isn't that then a result of your friction?
I understand in theory how it works, but I do not know how to calculate it... I just don't get it.
LowlyPion said:
You're looking for a kinematic equation then:
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
One that yields a from distance and velocity perhaps?
Ok, so I would roll tires with different pressures, measure the distance they each covered and the time it took, then use d=v2t-(1/2)at^2 to calculate a. The force of friction (Ff) will be the MASS of the tire times the acceleration. Fn will be the force of gravity times the mass (9.8)(x)
then the coefficient of friction will be Ff/Fn , and it will be negative, or positive?
Personally I might want to choose something that relates initial velocity and distance to stopping to try to eliminate time as something that has to be measured with precision.
In the original experiment we used time anyway. But that being said, is my formulae correct?
Sure. If you have the time and distance and know the initial velocity then you can figure the a.
As to whether μ is positive or negative ... it will always be positive (and usually less than 1 ... usually). It's basically a ratio of 2 weights right?
  • · Replies 60 ·
22K
