Measuring Current Flow in Open Circuit R Phase
This discussion focuses on measuring current flow through the neutral wire when phase R is open-circuited in a three-phase circuit. The impedance per load is specified as 3 + 7j. Participants recommend using a clamp-on ammeter or a current transformer combined with an ammeter for direct measurement. For calculation, it is essential to compute the current in each phase and sum them as vectors, considering the 120-degree phase separation inherent in three-phase systems.
  • Understanding of three-phase electrical systems
  • Knowledge of complex impedance (3 + 7j)
  • Familiarity with vector addition in electrical engineering
  • Experience using clamp-on ammeters or current transformers
  • Research the principles of three-phase power systems
  • Learn about complex impedance and its applications in circuit analysis
  • Study vector addition techniques for electrical currents
  • Explore the specifications and usage of clamp-on ammeters and current transformers
Electrical engineers, technicians working with three-phase systems, and anyone involved in measuring and analyzing electrical currents in industrial applications.
lukus09
how do i measure the current flow threw the neutral wire if phase R is open circuited? the impedance per load is 3+7j
Measure current using a clamp on ammeter or a current transformer +ammeter.
If you wish to calculate the current, calculate the current in each phase and add them. The currents have to be calculated and added using vectors. Since this is a three phase circuit the currents in the three phases will be 120 degrees apart.
  • · Replies 19 ·
