Can Alleles Be Swapped Without Changing Inherited Traits?
  • Thread starter Thread starter Dadface
    Genetics
The discussion centers on a thought experiment regarding the nature of alleles and inherited characteristics. It explores whether swapping a set of alleles from one individual with equivalent sets from others would yield identical inherited traits. The conversation highlights that while alleles may be equivalent, slight differences could arise due to mutations and variations. The role of epigenetics is emphasized, indicating that gene expression and the resulting characteristics are influenced by factors beyond the DNA sequence itself, including regulatory modifications and stochastic processes. This area of biology is noted as complex and still under investigation, with many mechanisms capable of producing different phenotypes from identical genotypes.
Dadface
The following thought experiment popped into my head when I was driving from the shop;
Consider one set of alleles which is responsible for one of your inherited characteristics.Now suppose that we could swap that set ,without damage or interference,with equivelent sets from one or a multiple number of donors.Are those alleles exactly identical and would there be any change,no matter how slight, to the original characteristic?Expressing this another way, are the genes that you have exclusive to you?
Loads of other related questions spring to mind but I shall leave it here.:confused:
Biology news on Phys.org
If they are equivalent, then they are the same, by definition. I'm not sure what you're trying to ask.
Thank you Moonbear.What I mean is are they exactly the same in terms of the characteristics that are inherited ?Could there be slight and possibly as yet to be discovered differences?Suppose ,for example,that there were two people who did not have any ancestors in common(going back numerous generations)but who had the same genetic make up.Since these people inherited the majority of their genes from different sources would their inherited characteristics be slightly different or would they be as alike as say identical twins?
Genes can have mutations and variations, I think that is obvious. It depends on the function of the gene and the location of the gene swap (the tissue that's affected) what the phenotype will be.
There are instances in biology where the underlying DNA sequence of a gene is not the sole determinant of how that gene is expressed and how that gene influences the characteristics of the organism. Collectively, these instances fall under the category of epigenetics (see http://en.wikipedia.org/wiki/Epigenetics). Mainly these epigenetic controls consist of regulatory modifications to the genome (e.g. by affecting DNA methylation or packaging). However, in simplified systems (such as bacteria), there is evidence that the randomness (stochasticity) of gene expression and protein-protein interactions can cause phenotypic changes (see Kaern M et al. Nat Rev Genetics 2005, http://dx.doi.org/10.1038/nrg1615 and Choi PJ et al. Science 2008, http://dx.doi.org/10.1126/science.1161427).
This area of biology is still fairly new and much remains controversial and poorly understood. However, it is clear that there are many mechanisms by which identical genotypes can lead to non-identical phenotypes.
Wow this is interesting stuff.Thank you everybody.
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) he structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
