What is Paired Particles: Quantum Encryption Explained
  • Thread starter Thread starter Ahmes
    Particles
Ahmes
hello,
can anyone tell me what's the story about "paired particles" (e.g. paired photons)? I've heard about the "quantum encryption" technique, which uses a couple of photons who have some sort of link between them.
I am currently a high school student (learning physics), and in school we learned about the quantum aspect of wave interference - that the single photon turns randomly to one of the holes, but statistically, many photons act as we expect them to. I guess it has something to do with quantum encryprion.
help anyone?
thank...
Ahmes
If you bounce two particles off each other, they become "entangled." Entanglement means that the two particles must be in complementary states. For example, if one of the particles is spin-up, the other must be spin-down to conserve angular momentum. The interesting part is that you can't really say whether a particle is spin-up or spin-down until you measure it. When that measurement occurs on one of the particles, the other one might be all the way across the galaxy! Somehow the other particle has to know about the measurement of the first, even if it is very far away. In quantum mechanics, both particles are part of a single system; a measurement on any part of that system affects the entire system all at once, causing the other particle to immediately assume it's correct, complementary state.
- Warren
Sorry for my ignorance
Thank you very much for the reply.
you said that this thing happens when you "bounce two particles off each other". what exactly does that mean? Does it have anything to do with a photon becoming an electron and a positron? In which sort of experiment can you "entangle" two particles?
thanks again.
If you collide two particles, you'll have an entangled pair. There may be other ways to prepare them, but I mostly have seen collisions.
- Warren
Actually, in most EPR-type experiment involving entangled photons so far have used the spontaneous parametric down conversion to generate those photons. You have one incoming photon that excite a system. The system then decays via a two-step process, generating two photons that together have the same polarization as the original incoming photon.
More description here:
http://arxiv.org/abs/quant-ph/0106113
There are certainly other ways to get entangled particle. A cooper pair in a superconductor is one candidate. If you break a pair apart without destroying its coherence, they will form an entangled pair.
Zz.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
