Benefits of time dilation / length contraction pairing?
The discussion revolves around the concepts of time dilation and length contraction in the context of special relativity. Participants explore the utility and consistency of these concepts, their derivations, and the implications of their use in different inertial frames. The conversation touches on theoretical, conceptual, and mathematical aspects of these phenomena.
  • Some participants express confusion regarding the use of time dilation and length contraction, particularly in relation to the notation of primes in equations.
  • One participant questions the necessity of using separate equations for time dilation and length contraction, suggesting that a more consistent pairing could reduce confusion.
  • Another participant argues that time dilation and length contraction are consequences of the Lorentz transformation and Einstein's postulates, questioning whether the issue lies with the fundamental theory or its consequences.
  • Concerns are raised about the logical consistency of deriving reciprocal time dilation and length contraction from isolated examples, with some participants suggesting that a global understanding of special relativity is necessary for clarity.
  • There is a discussion about the empirical observations that time dilation explains, with some participants acknowledging its utility while still questioning the form of the equations used.
  • One participant challenges the assertion that the frames of reference are consistent, citing previous discussions and diagrams that illustrate their confusion.
Participants do not appear to reach a consensus on the utility and consistency of time dilation and length contraction. Multiple competing views remain regarding their derivations and implications, and the discussion remains unresolved.
Participants highlight limitations in understanding due to the notation used in equations and the interpretation of time and length in different frames. There is also mention of the need for a comprehensive view of special relativity to fully grasp the relationships between these concepts.
  • #151
DrGreg said:
neopolitan
In post #146 I gave the answer
[tex]t_B = t_A \sqrt{\frac{c-v}{c+v}}[/tex]​
which applies if A and B are both under the delusion that the events are co-located in their own frame. If they are both under the delusion that the events are simultaneous in their own frame, the same conversion factor applies, because for each [itex]L = ct[/itex].
As far as I can tell, that is exactly what you asked for. Or have I still misunderstood the problem?
And, JesseM, do you follow my logic and agree with my conclusion?
Yes, if we assume the events are colocated in one frame, then the time interval for the other observer to see them will just be given by the relativistic Doppler shift equation, and of course if that second observer assumes they are colocated in his own frame then he'll conclude the time between the events was the same as the time between his seeing the light from the events. And as you say, it works the same if we assume simultaneity.
  • #152
JesseM,
Did you or did you not apply "time dilation" so that in B's frame, the time between arrival of photons was less than it otherwise would be?
That is, you arrived at 10s, then applied time dilation and arrived at 8 seconds.
That's all I wanted you to do. The rest of the scenario is now irrelevant.
You asked at post #131 for a physical use for TAFLC, I see that as asking "where do you see time being contracted?" Here is my answer. "Precisely where you took 10s and contracted it to 8s."
cheers,
neopolitan
  • #153
neopolitan said:
JesseM,
Yes, 10 s was the time between the light from each event hitting B as measured in A's frame, 8 s was the time between the light from each event hitting B in B's own frame. Here we are dealing with two events that are colocated in B's frame (the events of the light hitting B's worldline, not the events that emitted the light in the first place).
So do you agree that the stuff about uncertainty about which frame they were "together" in was never relevant? Did you think it was relevant and then change your mind? It would be easier to understand your arguments if you would be explicit about when you have changed your mind or realized that part of a previous approach was not really important.
But this is not a use of the TAFLC, it's just the regular time dilation equation (if you start with the idea that the events happened 8 s apart in the frame where they were colocated and want the time in the frame where they were not colocated), or the inverse time dilation equation obtained by dividing both sides by gamma (if you start with the idea that the events happened 10 s apart in the frame where they were not colocated and want the time in the frame where they were colocated). As I said before, the TAFLC is different:
The trick with the TAFLC is that if you write it as t' = t / gamma to contrast with the standard time dilation equation t' = t * gamma, then in order for the notation to be consistent you have to be assuming the same thing about the unprimed frame being the one where the events are colocated in both cases.
  • #154
Try going back to the original post in this sub-thread.
Answer the question I asked there. Then you might see why the "togetherness" had some relevance.
The reason why the scenario is no longer relevant is that you came up with what I wanted you come up with another way. I thought you might grasp something from the process, but it doesn't seem like it. (Here, I should point out that what I want you to grasp may not be right, so don't take this as a personal affront.)
I feel that we could circle forever on this.
You wanted to break things up into TAFLC and "inverse time dilation". I'd prefer "temporal contraction" being the relativistic effect on time which is analagous to length contraction as well as being "inverse time dilation". I don't make such a huge separation between them, this might be because I visualise things a different way.
This visualising things a different way may be why I find it hard to credit that you had so much trouble coming to a result with the scenario I posited - where it is possibly due to the fact that the explanation I gave was more oriented towards someone who visualises things the way I do.
I'm going to withdraw, enjoy my Easter, and if I can think of another way to try to explain the physical significance of temporal contraction (or TAFLC or inverse time dilation), I'll let you know in due course.
cheers,
neopolitan
  • #155
You mean the question "If A and B have identical rods and identical clocks, what sort of conclusions will B come to" from post #133? I thought I already answered that. If it wasn't that, which question/post are you referring to?
I don't see how this has anything to do with visualizations, terms like "TAFLC" and "inverse time dilation" are ultimately supposed to refer to specific equations where the terms have specific physical meanings, if you aren't clear on this then any "visualizations" you come up with will be too ill-defined to have any real meaning. In the original diagram you reposted in post #5 of this thread, I specifically defined the TAFLC as t' = t / gamma, in contrast to the normal time dilation which I wrote as t' = t * gamma. What you're talking about is just dividing both sides of the normal time dilation equation by gamma, a simple algebraic operation which gives t = t' / gamma, which is different than the TAFLC above because if you want the notation to be consistent the unprimed frame has to be the one where the events separated by a time interval of t are colocated. If you just want a change in terminology from what I wrote in that diagram, and want to call the equation t = t' / gamma the "TAFLC", then this is just a semantic issue, I'm fine with calling that equation whatever you want to call it as long as you agree that it's nothing more than the ordinary time dilation equation with both sides divided by gamma. But if you think the TAFLC as I defined it, t' = t / gamma (with t the frame in which whatever events we're dealing with are colocated), is somehow applicable to the problem with the light hitting B, you have to explain what t and t' are supposed to represent physically. And if you just aren't willing to pin down what you mean by terms like "TAFLC" and "inverse time dilation" in terms of specific equations where the terms have specific meanings, then the whole discussion is pointless because pictures in physics are essentially just ways of illustrating the math (as is true of all Minkowski diagrams, for example).
When did I have trouble coming to a result? I didn't immediately give an answer because, as I think you now acknowledge, you misunderstood my question about dealing with multiple possibilities and thus gave me a misleading answer which made me unclear what you could be asking. Once this was cleared up I gave a pretty detailed numerical example.
All you need to do is give the equations which are supposed to correspond to these words (preferably side-by-side with how you'd write the normal time dilation equation so I can check that the notation is consistent), and what the terms in the equations represent physically. In the meantime, happy Easter!
  • #156
Jesse,
Attached is a diagram of the sort of situation I had in mind.
Note that I don't have the events which created the photons we have been discussing (red and green arrows, at 135 degrees from the tA axis. The events could have taken place millennia ago, really all that I am concerned about is the separation between the arrivals of the photons.
The diagram is in drawn in terms of the A frame.
B is moving towards where the events took place, which means that B intercepts the photons before A (in any frame) and B is closer than A to where the events took place (in any frame).
Down in the bottom right hand corner is an indication of what A and B would take to be "togetherness" for events which could have produced the photons.
Note that initiating events that were 1) together spatially for A and 2) could have produced the photons are further apart temporally than intiating events that were 1) together spatially for B and 2) could have produced the photons. This is true in any frame.
Note also that initiating events that were 1) together temporally for A and 2) could have produced the photons are further apart spatially than intiating events that were 1) together temporally for B and 2) could have produced the photons. This is also true in any frame.
Remember in the first post in this subthread, I said that the delay of t between the arrivals of the photons meant that, to have been emitted together, they were either emitted with a delay of t from the same location (relative to A) or simultaneously with a separation of L (relative to A). These values are also marked in the bottom right hand corner.
Now the thing that concerns me is that if I were to plug your figures into my drawing, I don't think I would arrive at 16 seconds between the arrival of the photons for A and 8 seconds between the arrival of the photons for B. I'd arrive at 16s and 12.8s.
Clearly something is wrong somewhere, either with my understanding, my explanation or your assumptions.
cheers,
neopolitan
  • #157
neopolitan said:
Jesse,
Keep in mind that if you draw 1-second ticks along A's time axis and 1-light second ticks along A's space axis, then also draw similar ticks along B's space and time axis, then when drawn from the perspective of A's frame, B's space and time axes are not merely rotated versions of A's, in A's frame the distances (in the diagram) between ticks on B's axes are greater than the distances between ticks on A's axes. You can sort of see this if you look at the diagram from post #5, where in the diagram from the unprimed perspective you can see that the distance between pink events on the light blue space axis of the unprimed frame is just 4 light-seconds, and the distance between pink events on the yellow time axis of the unprimed frame is 4 seconds; but in the diagram from the primed frame, the light blue and yellow axes are not only slanted, but the distance along these axes between the same pink events also looks stretched (and the location of the three pink events in both frames was calculated using the Lorentz transform so I know they're correct).
  • #158
You mean like this?
  • #159
neopolitan said:
You mean like this?
Yup, like that (assuming the angle of the dotted lines isn't supposed to have any meaning), and same for the x-axes obviously.
  • #160
I thought about that shortly after I posted the drawing. The angle of the dotted lines, if they were to remain should be 135 degrees (signifying the speed at which a photon or information could reach A and assuming a c=1 sort of relationship between the x and t axes).
(The following is off-track somewhat.)
Now as I wrote it, I realized that "the speed at which a photon or information could reach A" is maybe a little misleading. It's not really that the photon is traveling to intercept A. It's more like the photon is everywhere (and everywhen) along its worldline and there is just a question of when and where the path of A through spacetime intersects that photon relative to when and where the path of B does, and vice versa.
That sort of thinking would upset Tam Hunt ... since unless you somehow shake off causality, it makes the universe highly deterministic - and predetemined at that. If a photon is everywhen along its worldline, and millions of years from now (in my frame, for want of a better frame) that photon is going to hit a descendant of mine, then does that mean that my descendent is predetermined? Note: I know that, without some very special conditions, a photon that I am colocated with will never be colocated with any decendant of mine. Less extreme though, I could trap a number of photons between two mirrors, leave them for a day and come back, then release them. Would my return to release the photons be predetermined by the abrupt end to the worldline of a number of the photons when they are absorbed by my inquisitive eyes?
cheers,
neopolitan
  • #161
But what do you mean by "the photon is everywhere (and everywhen) along its worldline"? We can't talk about the time dilation of a photon since it doesn't have any sort of internal clock, and we can't talk about what would be true in the frame of the photon since all inertial frames are sublight frames. It's tempting to think that since in the limit as an object approaches c relative to some external landmark like the galaxy, the distance between the two ends of the galaxy that the object passes approaches zero in the object's own frame, that somehow that means the distance really is zero "for the photon"...see my post #7 on this thread for a discussion of the idea. But you can't really use such a limit to define the "perspective" of a photon since certain things aren't well-defined, like what speed one photon would be traveling from the "perspective" of another photon (see my post #4 from the same thread).
  • #162
I had replied to this a while back, but the network disconnected me and lost the reply. Such is life. The fortunate (?) thing is that I have had a subsequent thought which I wouldn't mind addressing.
I was thinking more in terms of the diagram. If you look at the diagram, then you can't really say where the photons are. They are not somewhere on the red and green lines, they are the red and green lines.
For those who like to think about the perspective of a photon (there are some), then as you mentioned, everything happens for the photon in the same place, and at the same time. It was more of an aside than anything real. I don't think it proves or disproves predestination, in part because I don't think that information about when and where the photon's worldline ends is available until it ends. Remember that the comment was made in context of Tam Hunt (who has concerns about free will).
Anyway, I was conflating the diagram (with the worldline of the photon laid bare) and reality (where the worldline of a photon can only be extrapolated using the information to hand, not known in detail).
Right, now on to my thought. We do agree, I hope, that in 4-space individual events all have a unique location, albeit differently identified by different observers. By this I mean that while two inertial observers may have different x,y,z and t values for an event, this does not mean that the event takes place at different 4-space locations.
In light of this, I want to confirm that the diagram I posted is correct.
In A's frame, A is moving along the tA axis at a rate of one second per second while B is moving at an angle to the tA axis such that the gradient of the line is given by 1/v. I have to admit that I initially thought of B moving along what B takes to be the xB axis. I see clearly that this is wrong, since that would equate to a speed greater than c. (I was thinking of an F(x) graph, where you plot F(x) on the vertical axis and x on the horixontal axis. This diagram shows an F(t) graph, where F(t) is on the horizontal axis and the gradient is therefore t/F(t) = 1/v, rather than v as I had in mind.)
B is actually moving along the tB axis, according to A, correct?
This would make sense, since that would mean B would be moving along the tB axis according to both A and B, and therefore according to any inertial observer.
Is that right?
cheers,
neopolitan
PS Yesterday I had no luck trying to post at all.
  • #163
In the same sense that dots on 2D surface like a sheet of paper or a globe have a unique location on that surface even though they can be assigned different coordinates in different coordinate systems drawn on that surface, right.
With the "gradient" defined as [tex]\frac{\Delta t}{\Delta x}[/tex], yes.
Right, the tB axis represents B's worldline.
  • #164
Ok, a new attempt. I am using a more rigorous diagram, using the figures you like, ie B is moving at 0.6c relative to A, and plotting numbers obtained from Lorentz Transformations. The green lines are the world lines of photon which pass the ends of the moving rod.
I'm just wondering, where is length contraction?
(I think I might know where it is, but drawing it clearly is difficult.)
cheers,
neopolitan
  • #165
Just draw in the worldlines of either end of the orange rod--both worldlines should be parallel to the tB axis, since both ends are at rest in B's frame--and then the horizontal distance between the worldlines (along any surface of simultaneity in A's frame, which are all parallel to the xA axis) represents the length of the orange rod at a single instant in A's frame, it will be 3/gamma.
  • #166
Damn,
I had it half drawn and was called away from my desk!
Anyways, here it is.
I don't want to follow cos' example by getting all wrapped around the wheels on what is "real", but ... it seems to me that what this diagram shows is that the rod is stretched across time and space (ie 1. the ends of the rod are no longer simultaneous, think clocks at each end, simultaneous in the rest frame, are not simultaneous to A, even if the speed is taken into account; and, 2. non-simultaneously, they are further apart), but the rod appears contracted to A.
Is that right?
I think this might be approaching the issue raised elsewhere by Saw.
As for me, it seems that maybe SAFTD might be a simpler feature to champion rather than TAFLC (although there are still benefits attached to TAFLC in my way of thinking). A benefit to SAFTD manifests in the derivation of the Lorentz Transformations from the Gallilean boosts, where you remove the assumption of instantaneous transmission of information (so you are discussing an event at a distance of x where x=ct and at t=0, t'=0 and the origins of the K and K' frames are colocated).
cheers,
neopolitan
  • #167
Diagram looks good...
True, if clocks on either end are synchronized in the rod's rest frame using the Einstein synchronization convention, then they will not be synchronized at a single moment in A's frame. But I think it's potentially misleading to say "the ends of the rod are no longer simultaneous", the ends are just physical objects which trace out different worldlines in spacetime, they don't have any intrinsic "opinion" about simultaneity, all claims about simultaneity are based on human definitions of coordinate systems. The rod's orange "world-sheet" can be sliced up in different ways, that's what the relativity of simultaneity is all about.
If you say the rod "appears" to be contracted to 2.4 light-seconds in A's frame, you should also say that it "appears" to be 3 light-seconds in B's frame; alternatively you could say the rod is 2.4 l.s in A's frame and it is 3 l.s. in B's frame, the important thing is not to see one frame's definitions as "more correct" than any other's.
Yes, I would say the SAFTD is a lot simpler conceptually, and wanting to know the distance between two events in a frame where they're non-simultaneous if you know the distance in the frame where they're simultaneous is the sort of problem that might actually come up in the course of a practical SR scenario.
Can you give an example? It sounds like you might be talking about a pair of events where one is at (0,0) and the other is at (ct, t) but in that case there wouldn't be any frame where they were simultaneous, and the SAFTD applies to cases where two events are simultaneous in one of the two frames you're using.
  • #168
I've been in trouble for showing alternative derivations before.
Nevertheless, the situation I am thinking about is analogous to the diagram with a red and green photon worldline, but with one photon which could have come from anywhere (along its path) and any time. Two observers are initially colocated, one travels away at v, and the photon passes one observer then the other one.
The observers consider themselves to be at rest and the other to be moving. Both assume that the event that spawned the photon occurred when they were colocated with the other observer. Each observer will come to the conclusion that the spawning event occurred at x=ct (x and t in their own frame).
Using Gallilean boosts (ie ignoring relativity), both observers would calculate that x'=x-vt (where v is negative in one instance and x' is the distance in the other frame).
However, Gallilean boosts assume instantaneous transmission of information and clearly don't work in this example.
Since information is not transmitted instantaneously, both observers will work out that the other observer must be affected by some temporal and spatial skewing (this is required to reconcile a single photon apparently coming from two different locations). And it's the same temporal and spatial skewing that each concludes must affect the other, since no frame is privileged.
Using these facts, you can calculate SAFTD and TD equations, then apply them to the Gallilean boost to obtain the spatial Lorentz transformation and, given the relationship between x and t, you can also obtain the temporal Lorentz transformation.
(Actually you only need the SAFTD equation, but for completeness it helps to get both.)
If you can't work this through, I can do it for you later, but I am a little pressed for time at the moment.
cheers,
neopolitan
  • #169
Why would they both assume that? You agree that one of them must be objectively right and the other objectively wrong if they each assume the event occurred simultaneously with their being colocated according to their own rest frame's definition of simultaneity, right?
OK.
In Galilean physics they don't disagree about simultaneity, so in this case they could both be right that the event occurred simultaneously with their being colocated. However, the meaning of your terms is a little ambiguous. For example, say the event occurs at t=0 and x=-10 light-seconds in A's frame, and they are colocated at t=0 and x=0 in A's frame, and B is moving in the +x direction at 0.6c in this frame. Suppose also that the signal from the event moves at 1c in the +x direction in A's frame (which will mean it moves at a different speed in B's frame). In this case the signal will catch up with A at t=10, x=0, and will catch up with B at t=25, x=15 (again in A's frame). In B's own frame the time will be the same but the light was only moving at 0.4c in his frame, so the initial event was at x'=-10 and t'=0, and it hit B at x'=0 and t'=25. So, if x is the distance between A and the event in A's frame, and x' is the distance between B and the event in B's frame, in which case x=x'=10, meaning your equation isn't right. On the other hand, you may have meant that x is supposed to be the distance between the original event and the event of the light hitting B as measured in A's frame, while x' is the distance between the original event and the event of the light hitting B as measured in B's frame, in which case x=25, t=25 and x'=10, so this does work because 10 = 25 - 0.6*25. So it only works if both frames are talking about the distance x and x' between the same two events.
I wouldn't say Galilean boosts assume instantaneous transfer of information, you could have a Galilean physics where information can travel no faster than c in both directions in one preferred frame (the aether frame, perhaps), so in a frame moving at speed v relative to the first, signals could travel at a max of c-v in one direction and c+v in another.
I don't understand what you mean by that--there is no way to reconcile a single photon coming from two different locations in spacetime, that's a physical contradiction and only one of them can be correct if they both make this assumption. If the event that created the photon was simultaneous with A and B being colocated in A's frame, then it wasn't simultaneous in B's frame, and vice versa.
The TD and SAFTD are meant to apply to a single well-defined pair of events, not to a case where different frames disagree about where in spacetime one of the events occurred (which is different from disagreeing about the coordinates assigned to a single well-defined event). It is true that you get equations that look like the TD and SAFTD with your assumptions though. For example, let's use the same numbers for A's frame, so in this light from the event reaches B at t=25, x=15. Because of time dilation in A's frame, B's clock will only read 0.8*25 = 20 when the light hits it, so if B assumes the event happened at t'=0 in his own frame, he must conclude it happened 20 light-seconds away at x'=-20. So A thinks the original event happened 25 light-seconds away from where B was when the light struck him, and B thinks it happened 20 light-seconds away from where B was when the light struck him. But again, conceptually this has nothing to do with TD or SAFTD because they are each making totally incompatible assumptions about the spacetime location of the original event, whereas TD and SAFTD are derived using the assumption that we are talking about two events with well-defined locations in spacetime (and also using the assumption that the events have a spacelike separation and are simultaneous in one frame in the case of TD, or a timelike separation and are colocated in one frame in the case of SAFTD).
I also don't see how you can use your scenario to get a valid derivation of either of the Lorentz transformation equations, so could you explain that?
  • #170
I don't have time to go through it all right at this moment. All I can do is ask you to analyse the inherent assumptions in the Lorentz transformations. That's analyse, not recite because reciting will give what you know now rather than what you could know if you analysed.
To help you, think about why there is no offset (to or xo) in the equations.
Plus I reiterate:
There is no objective right or wrong here, unless you can uniquely identify individual photons. Note that I am using thought-experiment magic here, so the photon is detected by both observers without being absorbed by the first. If you prefer an expanding sphere of photons, you can have that instead so long as you don't pretend that you can see the whole sphere and work out the objective origin.
cheers,
neopolitan
  • #171
There's no offset because you didn't pick a single pair of events, you picked an event on B's worldline (receiving the photon) and then gave the observers two different assumptions about where in spacetime the photon was emitted. If they both agreed on the event in spacetime where it was emitted, then they both figured out the distance and time between the event of emission and the event of B receiving the photon in their own respective rest frames, their two answers would be related by the usual Lorentz equations:
[tex]\Delta x' = \gamma * (\Delta x - v * \Delta t)[/tex]
[tex]\Delta t' = \gamma * (\Delta t - v * \Delta x /c^2)[/tex]
In contrast, when they both define the distance and times using the assumption that the emission event happened simultaneously with A and B being colocated according to their own frames' definitions of simultaneity, they get the equations:
[tex]\Delta x = \gamma * \Delta x'[/tex]
[tex]\Delta t = \gamma * \Delta t'[/tex]
(note that even besides the lack of the extra factor with the v in it, the primes and unprimes are reversed here).
I don't see how you can go from one to the other, and I'm highly dubious that you have a coherent derivation yourself, but maybe you can prove me wrong when you have more time.
neopolitan said:
Plus I reiterate:
That assumption is fine, but what's problematic is that there has to be an objective truth about what event in spacetime corresponds to the photon emission (at least as long as we don't get into quantum uncertainty), whether or not the observers can "identify" this point; in SR problems we typically take the perspective of omniscient observers viewing spacetime from "the outside" as in spacetime diagrams, whether or not observers in the thought-experiment would actually have the technical ability to determine everything we state in the problem is not relevant. And in the form of the Lorentz transformation I posted above, we're definitely talking about the time and distance intervals between a single pair of events with well-defined locations in spacetime.
  • #172
You are still looking at it the wrong way.
There is a pair of events. The pair of events that the Lorentz Transformations are based on (the information that is in the transformations comes from those events).
Really there are three events:
  1. The event which spawned the photon. I don't care where or when that event took place because the photon could have be spawned anywhere on its worldline (anywhere on the appropriate side of the observers, of course) and be indistinguishable from any other photon spawned on the same worldline (again on the correct side of the observers).
  2. When and where the photon passes the first observer
  3. When and where the photon passes the second observer
As I say, I don't care that much about the first event and the Lorentz Transformations only uses the second two events. Yes I know that the "where" in the Lorentz Transformation is not about events 2 and 3 but about where the photon originated to cause events 2 and 3, which requires and extrapolation and when you make that extrapolation, you are using an assumption. What is that assumption?
Does this help?
cheers,
neopolitan
PS Writing out the whole derivation will take me an hour or more with all the LaTex and typo checking, this response took close to ten minutes. I'm not being difficult, I am just using the time I do have as best I can.
  • #173
Well, the Lorentz transformation works to relate two frame's answers for the distances and times between any pair of well-defined events whatsoever. And yes, this is a helpful clarification on the two events, you didn't correct me earlier in post #169 where I interpreted t' as the time B calculated in his frame between receiving the photon and when he assumed it was emitted, and t as the time A calculated in his frame between B receiving the photon and when he assumed it was emitted. As always, it's best to be specific as possible.
So, I'll look at that numerical example again with this clarification in mind. As before, assume that in A's frame B is moving at 0.6c and they were colocated at x=0 at time t=0. And as before, assume the light hits A at x=0, t=10, and catches up with B at x=15, t=25. If delta-x and delta-t are the distance and time between this specific pair of events, then we have delta-x=15 and delta-t=15. In B's frame, B is at position x'=0 when the light hits him, and because of time dilation his clock only reads t'=20 when it hits him. At this moment A must be 0.6*20=12 light seconds away in B's frame, and the distance between A and the light increases at 1.6c in B's frame, so backtracking, the light must have crossed A's path 12/1.6 = 7.5 seconds earlier at t'=12.5, and at this moment A must have been at a distance of 0.6*12.5 = 7.5 light-seconds from B, so a position of x'=-7.5. So for B, delta-x' between these events = 7.5, and delta-t' = 7.5.
But if this is what you meant when you said "Using these facts, you can calculate SAFTD and TD equations", then I'm still confused, because this delta-t is 2 times this delta-t', which is not the gamma factor if A and B have a relative velocity of 0.6c (likewise for delta-x and delta-x'). So how are you using these two events to derive time dilation and its spatial analogue? I think we need to clarify this first, since you said that once you have already derived these equations using your scenario, you "then apply them to the Gallilean boost to obtain the spatial Lorentz transformation". Unless you think this last part can be done without worrying about the specifics of how we derived TD and SAFTD--but in that case it'll be important that you're using the normal interpretation of TD and SAFTD, where we only use TD if two events are colocated in one of the two frames, and we only use SAFTD if the two events are simultaneous in one of the two frames.
  • #174
See the three diagrams, numbered:
1 (Galilean boost),
2 (one photon passes B, then A - indistinguishable from a photon from Event E - Galilean boost not applicable) and
3 (part of the way to Lorentz Transformations).There are six numbered equations in diagram 3.
Put (5) into (6) or (6) into (5) and you have:
[tex]G = \gamma[/tex] ... (7)
Put (7) into (1) and you have "SAFTD".
Put (7) and (4) into (2) and you have the spatial Lorentz Transformation.
Because x=ct and x'=ct', then you just divide through by c to get TD and the temporal Lorentz Transformation (noting that t/c = x/c2).
You are probably going to tell me I am wrong for some reason, but it's really a heck of a lot simpler than some of the derivations I have seen.
cheers,
neopolitan
PS You can call the result of (7) into (1) SAFTD, or inverse length contraction, or length dilation, or relativistic effect on lengths, or the spatial relativistic effect. Or whatever you like. Irrespective of what you call it, can you see the physical significance of it?
  • #175
Some clarifications to the last post (done in the early hours of the morning).
G to E 01 - (Galileo to Einstein) - shows the standard Galilean boost. There is an assumption of instantaneous transfer of information (or god-like powers to see everything at once).
G to E 02 - shows what happens when you remove the assumption of instantaneous transfer of information. E is an "event". I stress that it could be something that causes the emission of a photon, or it just could be an event along the path of the photon. A and B see the same photon (thought experiment magic).
G to E 03 - shows the reconciliation, with subscripts to show "according to ..."
In this process, it becomes explicit what sort of physical things your x, t, x', t' and, if you like, L and L' refer to. You may want to check that they are referring to the right sort of things in your terminology (ie in which frame are things simultaneous and in which frame are things collocated), but I think you will find that while saying "time and space are measured oddly" might sound less than rigorous, it is actually more intuitive. To work out the simultaneity/collocation issues, you really have to already understand so I think it is a stage that should come after you have given a derivation.
cheers,
neopolitanPS I had another thought about the simultaneity/collocation thing. I agree wholeheartedly that you can work out TD and LC from taking into consideration which frames have co-local ticks of a clock and which frames a rod is simultaneous along its length (or, in other words, frames which have non-simultaneous but collocated events and frames which have simultaneous non-collocated events). But using the derivation shown in #174, this can be worked out retrospectively, rather than having to be known a priori. So, it is not just a case of confusing the new learner, I think that my derivation requires less a priori understanding (and I'm willing to accept that this might not be the case).
  • #176
You are right, they don't need to assume that the event that spawned the photon occurred when they were collocated with the other observer.
This was very poorly worded (particularly the words I have made red) and I apologise for the confusion it created.
It is better to say that when the photon passes B at tB' in my later diagram (my poor phrasing quoted above was in post #168, diagrams were post #174), B could assume that one of the possible spawning events could have been at ctB' when A and B were collocated.
When the photon passes A at tA, A could assume that one of the possible spawning events could have been at ctA when A and B were collocated.
I do believe that neither A nor B are wrong in being able to make these assumptions. Being objectively right never comes into it.
Where I wrote "Both assume", I should have written "Both could assume". It made sense to me at the time :smile:
cheers,
neopolitan
  • #177
While awaiting a response on https://www.physicsforums.com/showpost.php?p=2165684&postcount=174". That diagram only showed length contraction (LC).
I have developed three more diagrams, one for time dilation (TD), one for spatial analogue for time dilation (SAFTD) and one for temporal analogue for length contraction (TAFLC).
In each of the diagrams I have tried to be consistent with the use of colours. I hope that the sheets (light blue and light orange) are easily understood. Trying to explain briefly, depending on what is being shown:
the blue sheets have a spatial of L or a temporal width of 1 tick in the A frame
the orange sheets have a spatial width of L or a temporal width of 1 tick in the B frame.
The darker blue bar shows either a length L or the period between two consecutive ticks in the A frame. The darker orange bar shows either a length L or the period between two consecutive ticks in the B frame.
The green bars show measurements by A of a length or period in the B frame.
The purple bars show measurements by B of a length or period in the A frame.
For completeness, I will repost JesseM's diagram (which contains some of the information, but not all).
cheers,
neopolitan
It seems that I can't post diagrams at the moment. So, I have posted them all on one web page http://www.geocities.com/neopolitonian/index.htm".
I'm aware that only a few may understand the background to the diagrams. Therefore, I thought I might try to explain a little.
Length contraction manifests in situations such as when two rods of the same rest length pass each other. Both will observe the other to be contracted.
Time dilation manifests with in situations such as when you have two identical clocks where one is in motion relative to the other. Time dilation is not so easily observed. Part of this is because photons received from a clock moving away from you will be spaced out due to the movement of the clock away from you, even before taking into account relativity. The combined effect of standard doppler and relativity is "relativistic doppler" and in the diagrams the overall effect is to double the period between "moving" ticks compared to "stationary" ticks where v=0.6c. A pure doppler effect for one observer assumed to be stationary with the other observer is in motion at v=0.6c would be: (c+0.6c)/(c+0) = 1.6. To make relativistic doppler, we apply a gamma of 1.25 to get 1.6*1.25 = 2.
To understand spatial analogue for time dilation (SAFTD) you really need to look at the diagram. Note that the period between ticks is stretched out for B relative to A. This is the effect of time dilation. The length of L in B's frame is stretched out in A's frame in a similar fashion.
As for the temporal analogue for length contraction (TAFLC), this is similar to the idea of two rods passing each other. Imagine there are no doppler considerations, in the time it takes the clock in A's frame to tick once, according to A, the clock in B's frame has not had enough time to tick. In other words, according to A, 1 tick in A = less than 1 tick in B. This means that the clock in A will tick more, so more time will elapse in A than in B.
Clear as mud?
  • #178
The labels on the time dilation diagram appear to be backwards. You label the purple segment the time dilation of B looking at A, but that appears to be the time dilation that A sees when it looks at B's clock--it's the difference in A's time coordinates between two events on the worldline of B's clock that are separated by 1 second in B's frame (and the height of the purple segment is greater than 1 second in A's frame, hence the 'dilation'). Likewise, the green bar seems to show the time in B's frame between two ticks of a clock at rest in A's frame, so that should be "time dilation of B looking at A" rather than "A looking at B". Unless I'm misunderstanding what "looking at" is supposed to mean (I interpreted 'A looking at B' to mean how B's clock behaved in A's frame).
  • #179
Why is instantaneous transfer of information relevant? Even in a Galilean universe it could be true that information has limited speed (for example, the fastest information transfer might be vibrations in the aether which travel at c in the aether frame). The coordinates an observer assigns to an event are done in retrospect, once I have already received information about an event. For example, if an event happens 12 light-seconds away from me at t=0, then if you have instantaneous transfer of information I'll learn about the event at t=0, while if information only travels at c I won't learn about it until t=12; but in the latter case I'll take into account the speed of the signal and backdate the event to t=0, so the coordinates are the same either way.
In this diagram, I take it t refers to the time in A's frame the light reached A, and t' refers to the time in B's frame the light reached B? If so it also seems that x refers to the position of the photon at t=0 in A's frame, while x' refers to the position of the same photon at t'=0 in B's frame (because of the relativity of simultaneity these must refer to different events on the photon's worldline). So in each frame you're calculating the distance and time between a totally different pair of events, correct?
It still isn't really clear to me...is A still measuring the distance and time between an event #1 on the photon's worldline (the event on the photon's worldline which in A's frame is simultaneous with A and B being colocated) and the event of the photon passing A, while B is still measuring the distance and time between a different event #2 on the photon's worldline (the event on the photon's worldline which in B's frame is simultaneous with A and B being colocated) and the event of the photon passing B? Or are the assumptions supposed to be different in this diagram? (or did I misunderstand the assumptions of the previous diagram?) If I'm getting the assumptions wrong, can you try to explain in clear terms what two events A is measuring the distance x and time t between, and likewise what two events B is measuring the distance x' and time t' between?
  • #180
Time dilation continues to be a problem.
What the diagram tried to show is a value seen from the A frame (from the A frame, ticks are all colocal) such that tB = gamma.tA. Since someone said a while back:
JesseM said:
The usual convention is that the unprimed t represents the time interval between two events on the worldline of a clock as measured in the clock's rest frame (so both events happen at the same spatial location in the unprimed frame, and t will be equal to the time interval as measured by the clock itself), whereas the primed t' represents the time interval between the same two events in a frame where the clock is moving (so the events happen at different locations in the primed frame).
That means that, according to A, tB = t' and tA = t, therefore:
t' = gamma.t
which is time dilation.
I could learn to like time dilation more if the stretching of the time axis in B's frame is time dilation and/or I am allowed to explain something like this:
Application of the gamma of 1.25 is time dilation and the stretching of the tB axis.
This would mean that the darker orange line is time dilation for A and the dark blue line is time dilation for B.
I'm happy with that.
But you can see that time dilation is such a totally different thing to Length contraction, which we have covered before, and that in the SAFTD diagrams the same would apply, the darker orange line would be SAFTD for A and the dark blue line would be SAFTD for B.
Are you happy with that?
What you can't really do though, is measure these values directly. Even to show it on the diagram is difficult, I would have to animate it or show a rotation around the origin of the axis (which may introduce problems). You can measure the time dilation indirectly in either of the ways described above (relativistic doppler or some variant of the twin's experiment).
You might say they have already tested it and showed that it works, and I would say "yes, they have done so, indirectly". What they have not done is something equivalent to directly measuring length contraction which could be done by simply passing two rods past each other - and both would measure the other to be shorter.
If you can come up with an experiment in which both observers can directly observe the other be time dilated, I'd be curious to know about it. I think that relativistic doppler is as close as you can get.
I've posted updated TD and SAFTD diagrams (Attempt 2) http://www.geocities.com/neopolitonian/index.htm".
cheers,
neopolitan
  • · Replies 45 ·
  • · Replies 63 ·
  • · Replies 36 ·
  • · Replies 34 ·
  • · Replies 16 ·
