Nuclear Physics, portons and neutrons
The discussion focuses on calculating the mass and binding energy of an oxygen nucleus composed of 10 protons and 10 neutrons. The mass of the constructed nucleus is approximately 16.096 atomic mass units (u), which is close to the expected mass of 15.994915 u for oxygen. The binding energy is derived from the change in mass, calculated as -0.101085 u, leading to a negative binding energy, indicating energy loss due to mass loss of the nucleons. The calculations utilize Einstein's equation E=mc² and emphasize the significance of understanding mass changes in nuclear physics.
  • Understanding of nuclear physics concepts, specifically nucleons (protons and neutrons).
  • Familiarity with Einstein's mass-energy equivalence formula, E=mc².
  • Knowledge of atomic mass units (u) and their significance in nuclear calculations.
  • Basic grasp of binding energy and its implications in nuclear stability.
  • Research the concept of nuclear binding energy and its calculation methods.
  • Explore the differences between the masses of protons and neutrons at rest.
  • Learn about the stability of isotopes and how binding energy affects it.
  • Investigate advanced topics in nuclear reactions and energy release mechanisms.
Students studying nuclear physics, educators teaching atomic structure, and researchers interested in nuclear stability and energy calculations.
aimslin22
You have 10 protons and 10 neutrons to paly with (mass of oxygen = 15.994915)
a. What is the mass of an oxygen nucleus that you build with equal numbers of protons and neutrons?
b. What is the binding energy of this nucleus?
E=mc^2
for a.
There are 8 protons in an oxygen, so 8 neutrons as well. Thus...
16(1.67x10^-27)=2.672...x10^-27
in us its about 16.096u...isn't suppose to be exactly 16, or is it close enough?
for b.
E=mc^2- except m is the change in m, so would it be 16.096-15.994915?
You are right!
minor things:
mass of neutron at rest and proton at rest are not exactly the same.
However, In three significant figures, it is 1.67 E-27 kg, so you are right.
for b,
E='delta'mc2
delta mass means change in mass, change is always calculated as final minus initial
so its mass final minus mass initial
hence change in mass is actually 15.994915 - 16.096 = -0.101085 u
and binding energy is -0.101085*c2
Binding energy is minus, because the question is done in terms of energy loss
If the question is asking "how much energy is needed to break the nucleons in an oxygen nucleus apart", hence the mass final (when the nucleons are free) will be bigger than initial (when the nucleons are bonded together). And in this case energy will be positive (as energy input, not loss).
Thanks so much!
  • · Replies 21 ·
  • · Replies 33 ·
