Constructing Infinite Sequence in R: Well-Ordering of Reals Explained
  • Context: Graduate
  • Thread starter Thread starter Ookke
The discussion revolves around the well-ordering of the real numbers and the implications of total orders on constructing infinite sequences. Participants explore the existence of sequences that do not have a least element under various total orders, the role of the Axiom of Choice, and the properties of uncountable sets and ordinals.
  • Some participants propose that for any total order in R, it is possible to construct an infinite sequence that approaches a limit point, suggesting that such a sequence would not have a least element.
  • Others argue that the Axiom of Choice is necessary for the existence of such sequences, and acceptance of this axiom is not universal among participants.
  • A participant questions the assumption that an uncountable interval can always be split into two uncountable parts, presenting a counterexample involving ordinals.
  • Another participant discusses the implications of the existence of uncountable ordinals, specifically referencing the smallest uncountable ordinal, ω₁, and its properties.
  • Some participants express uncertainty about the existence of sequences that can cover entire uncountable sets, questioning the intuition behind such sequences.
  • One participant shares a personal anecdote about technical issues faced while posting, emphasizing the importance of preserving work in online discussions.
  • A later reply retracts a previous statement about well-ordering, indicating confusion about the existence of subsets without least elements under certain assumptions.
Participants do not reach consensus on the implications of total orders and the Axiom of Choice. Multiple competing views remain regarding the properties of uncountable sets and the existence of sequences without least elements.
Some claims depend on specific definitions of order and the acceptance of the Axiom of Choice. The discussion includes unresolved mathematical steps and assumptions that may not be universally accepted.
Ookke
If < is any total order in R, isn't it always possible to construct an infinite sequence
x1 > x2 > x3 > ... > y for some limit point y in R.
It seems to me that {x1, x2, x3, ...} is then a subset of R that does not have
least element in this ordering. No total order in R can be well-order?
The axiom of choice says that such a sequence exists. You may or may not accept that axiom.
Why would it?
Do keep in mind that a total order on R does not have to bear much resemblance to the usual order.
Hurkyl said:
Why would it?
It's just an intuition of that uncountable set is necessarily kind of dense for any order, not just the common order.
I had in mind two assumptions which seem quite natural:
1. Uncountable set of reals must have uncountable interval (a,b) for any order <.
2. It's always possible to split uncountable interval into two parts, both uncountable.
Then what follows, we can split (a,b) into two parts, select x1 from the upper part. Then split lower part again into two parts, select x2 from the new upper part, and so on. This way should be formed a sequence {x1, x2, ...} where x1 > x2 > ... for the order <, and the sequence does not have a least element.
I'm just developing the idea, but if this is already flawed, I would appreciate any point.
This is demonstratably false, by a rather slick argument. It depends on two facts:
(1) The class of all ordinal numbers is well-ordered
(2) There exists an uncountable ordinal
Therefore, there exists a smallest uncountable ordinal number; let's call it [itex]\omega_1[/itex].
Now, consider the (uncountable) half-open [itex][0, \omega_1)[/itex] of ordinal numbers. If you choose any ordinal [itex]\alpha[/itex] in this interval, we have:
* [itex][0, \alpha][/itex] is countable,
* [itex][\alpha, \omega_1)[/itex] is uncountable.​
In particular, every Dedekind cut of [itex][0, \omega_1)[/itex] has a countable lower part.
Ok, thanks. Had fun trying, now I need to learn some ordinals.
Since you're researching it anyways -- it might interest you to look at another counterexample you can create using [itex]\omega_1[/itex]: the long ray.
I found an interesting article about smallest uncountable set:
http://www.math.fsu.edu/~bellenot/class/su08/found/other/omega-one.pdf
From there, I understood that it's possible to have uncountable set X for which every [itex]seg(y) = \{x\in X | x < y\}[/itex] is countable. This is exactly against an idea I had for proving my second assumption (yes it hurts, but I don't care).
But why is it impossible to have a sequence [itex]\{x_n\}[/itex] in X that takes up the whole X, i.e. for any x, [itex]x < x_n[/itex] for large enough n?
Existence of such a sequence seems almost obvious to me, and this would be enough to prove X as union of [itex]seg(x_n)[/itex] countable. Or is it just that because of initial assumptions, we must deny this kind of sequences. Do you happen to know any "real-world" example where any sequence cannot take the whole set?
And since we know [itex]\omega_1[/itex] isn't countable, that tells you why it's impossible.
If this seems obvious to you, that just means your intuition isn't equipped to deal with orders of uncountable cofinality. ("cofinality" measures this quality of orders)
"Real world" is very much in the eye of the beholder. As I mentioned in my previous post, [itex]\omega_1[/itex] can be used to construct counterexamples, such as the long ray -- which tells geometers if they want to study more "normal"-looking spaces, they need to require that manifolds aren't merely Hausdorff and locally Euclidean... one must also insist on second countability.
I've personally explicitly used uncountable ordinals in proofs because my preferred method of applying the axiom of choice is to use the well-ordering theorem along with transfinite iteration1.
I've also explicitly used them to help understand nonstandard analysis. (In particular, to understand just how ugly the hyperreals look when studied externally)
1: This refers to a form of transfinite induction that I find particularly natural, but I don't think it's a standard term.
discountbrain said:
This is the most messed up forum I've ever seen. It kept going round and round saying I wasn't logged in and then it said I was. I wrote my proof that the reals can't be well ordered and went to post it and then it said I wasn't logged in and erased it.
Whenever I write a long post for ANY online forum, I always Select All and Copy it before I hit Submit. That's because every website has occasional hiccups and sometimes your browser loses your text. It happens often enough that if I write something long or complicated enough, I'll make sure to save it in my Copy buffer just in case.
I actually picked up this good habit on the Craigslist forums, which used to have a fairly high frequency of these types of errors.
In any event, you should first convince yourself that you can prove that the existence of a well-ordering of the reals is equivalent to the Axiom of Choice. If you can then prove that no well-order exists, then a) If you assumed the negation of AC you have re-proven a known result; or b) If you assumed AC, you have discovered an inconsistency in mathematics and you will become famous.
So if you really have a proof, it's worth cleaning it up and posting it again. Not so much because I believe you've discovered an inconsistency in set theory; but because the effort to re-write and think through the math will help you learn more about the subject.
Over the years I always find that whenever I write something and the computer eats it, it comes out much better when I rewrite it.
For an arbitrary total ordering there is no notion of distance.
The Axiom of Choice guarantees that any set can be well ordered.
I'll have to retract what I said. If <* well orders R then each subset of R has a least element with respect to <*. I was thinking of a nonempty set {x: a<*x<*b} or {x:a<*x} with respect to <*. This should be a valid subset of R with no least element. But such a set by assumption should contain a least element, L ≠ to a, but there appears to be no way to prove there are numbers in this set between a and L with respect to <*. The fact that I can write such a set suggests that it exists and has no least element with respect to <*. The conclusion is If W.O. is correct there does exists an ordering <* such that there is no S subset of R such that
{x: xεS, a<*x<*b} or interval (a,b) with respect to <* exists.
I was going to add more, but this thing keeps telling me I'm not logged in.
Try clearing your cookies and starting over. I've never had trouble with this site. I think they had some login issues a couple of weeks ago.
  • · Replies 50 ·
  • · Replies 28 ·
  • · Replies 17 ·
