SR Simultaneous Lines Drawn in the Sand
  • Context: Graduate
  • Thread starter Thread starter geistkiesel
    Lines Sr
The discussion revolves around the implications of simultaneity in special relativity, specifically through the lens of Einstein's thought experiment involving a moving observer and two light sources. Participants explore the conditions under which events perceived as simultaneous in one frame may not be simultaneous in another, examining the roles of motion and the speed of light.
  • One participant describes a scenario where an observer in a moving frame detects photons emitted from two stationary sources, A and B, and questions whether these events are simultaneous in both frames.
  • Another participant reiterates Einstein's argument, stating that if an observer is equidistant from two light sources when they emit light, they should detect the light simultaneously, but challenges this by noting that the moving observer will not perceive the events as simultaneous due to their motion.
  • A different viewpoint suggests that the moving observer will receive the photon from B before the photon from A, emphasizing the impact of the observer's motion on the timing of light detection.
  • Concerns are raised about the assumptions underlying the thought experiment, particularly regarding the instantaneous travel of light and the implications for simultaneity.
Participants generally disagree on the implications of simultaneity in the thought experiment. While some support the idea that the moving observer will perceive the events as non-simultaneous, others question the assumptions made in the reasoning, indicating a lack of consensus.
Participants express uncertainty about the assumptions regarding the speed of light and the conditions of the thought experiment, particularly concerning the measurements and the implications of the moving observer's position at the time of photon emission.
  • #31
ram2048 said:
that makes NO sense.
A and B flash. observer M is in the middle WHEN they flash. He immediately accelerates to light speed in the direction of B.
Photon from A never reaches him.
Photon B is intercepted halfway to B
your statement is recognition of the stupidity of SR theory.
  • #32
russ_watters said:
Fine. I am Elvis.
Saying it doesn't make it true and a thought experiment is only useful if it conforms to the theory it is used to describe.
it is also useful if the thiought proes the theory wrong.
  • #33
ram2048 said:
so. here's what I'm getting from everyone trying to confuse the issue...
if I'm in the middle of A and B, and they emit photons towards me, no matter WHAT i do, move left right up down side to side stand on my head, WHATEVER...
i will always get hit by photons A and B at the same time.
is THAT what they're saying?
No. If you are the middle of he photons when they are emitted and you reamin there th ephiotons will arrive at the saem time. If you move like the experiment here, the photons will arrive at difeent times. Bullets, photons or craw;ing ants, the same is true. Keep everything in a straight line. It is the simplest of simple.
Doc Al is throwing useless bull **** around to distract.
Read the first post in this thread. As the moving frame passes the stationary frame when M' in the moving frame was at M in the stationary frame, the photons were emitted in the stationary frame simultaneously, and the photons were detected at this very instant simultaneously in the moving frame.
  • #34
jdavel said:
Pergatory,
Doc Al is right.
If two lights flash simultaneously (in my frame) and the distance from me to each one is the same at the time of the flashes, then light from the two flashes reaches me at the same time. That's what it means for light speed to be a constant with respect to all observers.
Your bullet analogy let's you down because the bullets are traveling at constant speed with respect to the shooters, but if you are moving wrt the shooters, the bullets are moving at different speeds wrt you.
If you want to get to the point where constant light speed and all its consequences seem more intuitive, stop thinking about bullets!
Read the first post in this thread. As the moving frame passes the stationary frame when M' in the moving frame was at M in the stationary frame, the photons were emitted in the stationary frame simultaneously, and the photons were detected at this very instant simultaneously in the moving frame. Do you understand?
  • #35
so they DON'T hit you at the same time if i move left or right.
which is what i thought, so why the arguments if everyone agrees?
  • #36
jdavel said:
ram2048,
Sounds like you have a real solid understanding of this theory! :wink:
In the first post of this thread the moving observer at M' was at M the midpoint of sources of photons when the photons were emitted simultaneously. These photons were instantaneously detected in the moving frame as the were emitted in the stationary frame. The moving frame detected the simultaeous emission of the photons in the moving frame. .
Using the detected arrival times of the photons in the moving frame, SR theory calculates that the photons were not emitted simultaneouslly in the moving frame. THE PHOTONS WERE DETECTED SIMULTANEOUSLY IN THE MOVING FRAME AT THE INSTANT THE PHOTONS WERE EMITTED IN THE STATIONARY FRAME.
All you theorists can argue all you want about SR theory, speed of light, Einstein, laws of physics, constancy of the speed of light foreever. The fact of the observation the photons were emitted simultaneously in the moving frame remains invariant under any theoretical perturbation.
Your problem is one of embarrassment when you ponder: "How could I ever have accepted special relativity in the first place?" Like I said, it is your problem, you solve it.
  • #37
Doc Al said:
Not sure what you are measuring with these photo-sensitive strips.
quote geistkiesel: "Were the photons emitted simultaneously in the stationary frame also emitted simultaneously in the moving frame?"
No.
In the first post of this thread the moving observer at M' was at M the midpoint of sources of photons in the stationary frame when the photons were emitted simultaneously. These photons were instantaneously detected in the moving frame as they were emitted in the stationary frame. The moving frame detected the simultaeous emission of the photons in the moving frame.
This is an experimental observation.
And you say no they were not emmitted in the moving frame simultaneously.
  • #38
jdavel said:
Pergatory,
Doc Al is right.
What are you talking about " ...seeming more intuitve . . ?.Aren't observations intuitive enough for you?
  • #39
why must you use a moving frame and a stationary frame?
i think that's what is throwing me off
do one experiment where he's stationary and THEN do the exact same thing when it's moving
combining the two creates unnecessary confusion :P
1) A -> ________________M________________ <- B
1) A ____ ->____________M____________<- ____ B
1) A __________ ->______M______<- __________ B
1) A _________________ xMx _________________ B
2) A -> ________________M________________ <- B
2) A ____ ->______________M__________<- ____ B
2) A __________ ->__________M__<- __________ B
2) A ________________ ->______Mx ___________ B
2) A ______________________ ->__Mx _________ B
2) A ____________________________xMx _______ B
so I'm still not seeing the contradiction. everyone AGREES that the photons don't hit him at the same time in the moving frame. How hard would it be to do the calculations in reverse for the moving frame setup and acquire that the beams WERE emitted simultaneously BECAUSE of the frame shift, extrapolate it using M's velocity towards B.
  • #40
Why do we need two frames?
Because SR theory says that events that are simultaneous in the stationary frame are not simultaneous in the moving frame. We are talking about the same physical event. We must do the experiment with two frames, one stationary and one moving to test the theory. Hence we have the photo-sensitive strips to measuee the emission of the photons.
Here is the contradiciton that everyone is having such a difficult time with.
"Were the photons that were emitted simultaneously in the stationary frame also emitted simultaneously in the moving frame?"[/b ]
There was the record of the phosensitive strips attached to the moving frame that were exposed just when the photons were emitted in the stationary frame. These photo-sensitve strips were within a photon wave length of the emitted photons at A and B in the stationary frame when they wee exposed.
SR theory says, the photons were not emitted simultaneously in the moving frame. SR Theory gets to work backwards in time and redo the physical events that occurred there.
  • #41
Because we're disagreeing about what SR says when we analyze the exact same events from different frames.
Specifically, Geistkiesel is asserting that both of these diagrams are representing the exact same sequence of events:
Code:
A        M        B
A\       M       /B
A \      M      / B
A  \    M      /  B
A   \   M     /   B
A    \  M    /    B
A     \M    /     B
A      M   /      B
A      M  /       B
A     M  /        B
A     M /         B
A     M/          B
A       M       B
A\      M      /B
A \     M     / B
 A \    M    /   B
 A  \   M   /    B
 A   \  M  /     B
  A   \ M /       B
  A    \M/        B
We have two relatively stationary light sources (A and B), and an observer who starts in the middle and moves towards A.
The first diagram depicts how things look in the rest frame of the lights, if the lights are activated simultaneously.
The second diagram depicts how things look in the rest frame of the observer, if the lights are activated simultaneously.
However, there is a very important difference between the two diagrams; in the first diagram the photons do not meet M at the same event, however in the second diagram the photons do meet M at the same event.
The conclusion is that these diagrams cannot possibly represent the same events. Among the possible assumptions we can abandon, abanding that of absolute simultaneity is by far the most reasonable; the emission of photons is simply simultaneous in one frame but not the other.
  • #42
geistkiesel said:
Sure, but also as to the moving observers their clocks are t' = 0. The two '0' are the same.
You cannot arbitrarily set all clocks in O' to read t'=0. Doing so requires assuming that simultaneity is independent of the reference frames. Since that's what we're trying to discover, we can't just assume it.
No stipulation. I already stipulated that a moving observer using SR theory will conclude the photons were not emitted from A and B simultaneously in the moving frame. This is my stipulation. Can you agree to this?
Absolutely not! I don't want anyone making assumptions or stipulations about simultaneity. The entire point of Einstein's simple argument is to deduce the nature of simultaneity, not make assumptions about it.
I didn't stipulate to Einstein's postulate regarding the speed of light. I stipulated that SR theory would predct the photons were not emitted at A and B in the movinng frame. Do you have a problem with this? I am not going to debate the truth or falsity of the 'speed of light' postulate. If you say that the SOL postulate is fundamental to the SR derivation of simultaneity, so be it.
Once again, the point of Einstein's argument is to deduce the relativity of simultaneity, not assume it. The invariant speed of light is fundamental to any gedanken experiment concerning light. Without that, there is nothing to discuss.
The difference goes like this: simultaneity(SR) is placed in an enclosed logical box that cannot be entered and the contents modified, by cleverness, wit, dishonesty or mistake, or stipulation.
Don't be cute. Re-read my post and tell me exactly where you think Einstein's argument fails. If you can't accept the starting point--the invariant speed of light--then there is no point in continuing.
  • #43
geistkiesel said:
Doc Al is ambiguous. he is constantly observed to holding little factual tidbits so he can confuse the issue and distrct the flow of the thread. He isn't being honsest is what I am saying.
Please tell me exactly where I am being ambiguous. Refer to my post #2 in this thread. And dishonest? Come now, geistkiesel, have you run out of intellectual ammunition this early in the game?
He really is saying that an observer at M in the stationary frame will see the photons arrive at M simultaneously.
Anyone curious as to what I actually said, can read my own words in post #2.
I agree with your second paragraph. But some using SR theory calculate the photons that arrived at M simultaneously were NOT emitted simultaneously in the moving frame. In fact, before my exile, Doc Al and I discussed this issue in another thread.
We have "discussed" this many times. I am giving geistkiesel a golden opportunity to clearly and unambiguously point out the flaws in Einstein's argument. Is he up to the challenge?
  • #44
Re-read my response in post #2.
Right!
Now what possibly can you mean by this garbled statement? Are you talking about photons being detected by O'? Or O' deducing that they were emitted simultaneously? Speak clearly and stop wasting people's time.
  • #45
I defy anyone to understand your point. See my last post. Talk sense, man!
  • #46
how geistkiesel sneaks in an assumption of simultaneity
Assuming observers in the moving frame were posted at the right positions, then they WILL detect the photon emissions. But what makes you think that they will detect them SIMULTANEOUSLY? Since that is the point we are arguing, please give us your argument. (Note how Einstein's simple argument does not involve multiple moving observers. Why not deal with that argument directly?)
We all agree that the moving observer detects the photons as arriving at different times. Using that fact, plus simple assumptions of the invariance of light speed, Einstein deduces that the moving observer must conclude that the photons were emitted at different times. Every observation made in the moving frame--including the direct observation of the photon emissions by the moving observers--must agree with this conclusion!
Again, you merely ASSume, where Einstein argues.
I truly believe that you believe this. But you are still wrong. Rather than add questionable assumptions to Einstein's gedanken experiment, please deal directly with Einstein's simple argument.
Geistkeisel, I am making a special effort in this thread to be nice. Why don't you do the same?
  • #47
A Simultaneous Line in the Sand for Doc Al
The instant photons were simultaneously emitted from A and B in the stationary frame the photo-sensitve strips in the moving frame were exposed (|||) at both ends of the moving frame, at locations equally spaced from M'. This is the point, the only point. For your convenience we give another picture.
|||----M'----||| -->moving frame-->
-A-----M-----B-| XX stationary frame XX
This is the picture the instant photons were emitted from A and B in the stationary frame.
Said another way, the instant the photo-sensitive strips were exposed in the moving frame by photons emitted in the stationary frame..
Is this enough "sense talk, man"?
I title this: A Simultaneous Line in the Sand for Doc Al.
If you were from Texas, or had spent any time in Texas, maybe, just maybe you would be able to understand. And this even though it is common knowledge that Texans have half their brains tied behind their back, leaving one loose piece of gray matter to rattle around inside their skull cavities.
You defied anyone to understand the point. OK, someone from Texas, splain it to Doc Al.
  • #48
Doc Al's special effort fails the nice simultaneity test, again..
You don't know how to be nice. There were no added assumptions that corupted Einstein's gedunken. You just haven't realized that you've lost this game.
As from me to you, this is as nice as it gets.
  • #49
If the thought process of the theory is wrong, then it can easily be shown to be wrong through experimentation. You you can't prove that a theory is wrong if you don't address what the theory says. You are stating (assuming, as Doc says) the theory is wrong and building a thought experiment around how you think the universe should work, then offering it up as a proof that the theory is wrong. Sorry, science doesn't work that way.
Depending on the theory you apply to the thought experiment, the outcome is different. Which is right and which is wrong? Well, that's a question answered by experimentation.
What's funny about this is you think you're making an argument against Relativity, but what you are actually doing is demonstrating you don't even understand the scientific method, much less Relativity. The other guys here aren't so much defending Relativity as trying to explain to you what it says.
  • #50
geistkiesel's assumptions
Can observers in the moving frame detect the emission of the photons? Yes.
Are the marks on the photo-sensitive strips (caused by the photon emissions) in the moving frame equally spaced from the point M' (which passed M at the exact moment that the clock at M read t=0): YES!
Do the moving observers detect the photon emissions as happening simultaneously: NO!
By building incorrect assumptions into your "thought" experiment, you have left the realm of real physics. (As we know it today.)
Note that Einstein makes no such assumptions--and is able to simply deduce the relativity of simultaneity. Why not address Einstein's actual argument?
  • #51
geistkiesel's incorrect assumptions
You ASSumed that:
(1) The marks on the photo-sensitive strips (caused by the photon emissions) in the moving frame are equally spaced from the point M' (which passed M at the exact moment that the clock at M read t=0): True!
(2) That the moving observers detect the photon emissions as happening simultaneously: Not true!
As long as you insist on adding these assumptions, there is no point in continuing the discussion.
However, if you would like to discuss Einstein's actual argument--which you refer to constantly but obviously fail to grasp--have at it. If you truly understand Einstein's point, this should be no problem--since he makes fewer assumptions than you do.
  • #52
But how did you determine the distance between the photosensitive strips? If you made it the same length as A->B whilst in the moving frame then you have a problem because in the stationary frame this distance will be observed to be shorter than A->B due to Lorentz contraction. Thus in the stationary frame it is impossible for them to fall over A and B at the same time.
Ok, so you determined the length when the moving frame was actually stationary. But this doesn't help you either because when they start moving the moving observer will observe the distance between A and B to contract. Hence, again the strips cannot both be over the lights at the same instant in this frame.
The only way out of this mess is to accept the loss of simultaneity. This is why I suggested looking up the 'pole vaulter paradox' earlier because it points this out quite beautifully.
Matt
  • #53
makes no sense for SR to resolve that the photons were NOT emitted simultaneously.
it's a "Given" part of the experiment that they WERE emitted simultaneously as outlined in Einstein's original set up
there's a billion ways we can PROVE that they were emitted simultaneously hooking them up to synchronized clocks, photosensitive strips, whatever. that's not part of the argument, though. It's not even a possibility.
i think you SR supporters are somehow taking what einstein said the wrong way.
  • #54
No it's not given or automatically assumed. It is deduced, because the stationary midpoint observer received the lights at the same time. The midpoint observer just happens to receive the lights at the same time, that's the setup. Only because of this you can deduce that they were emitted simultaneously *in the stationary frame*, you can' assume anything else. You can't analyse this like you have a bird's eye view and like you can see everything at the same time. But if you want a graphical view according to SR, check this link:
http://casa.colorado.edu/~ajsh/sr/simultaneous.html
  • #55
yeah i saw that one from the other thread.
i still think the moving observer KNOWING he is moving towards B can extrapolate using his velocity/acceleration backwards to determine that they were emitted simultaneously.
i believe this is the proper way to come to the conclusion in the experiment, not calculate forward and find out that your perceptions are skewed, calculate backwards and find out where "reality" is.
  • #56
in any case this setup is different from cerulean and vermilion by virtue of being contained within 2 other bodies (the photon emitters) which have a known property of being "fixed" in the universe which provides excellent reference points to capture movement data to work backwards from.
you wouldn't have that luxury in the example in that link
  • #57
Yes, but the moving observer in fact considers himself stationary, and considers the embankement moving. If he extrapolates the values of his own measurements (his own speed = zero), he finds the SR result. Why would he think his measurements are faulty and correct them according to stationary frame's measurements? It's mutual. You can't determine who is really really really moving. Even if you assume there's a preffered frame, you can't detect your speed relative to it by any experiments.
  • #58
You assume absolute space by saying they are fixed. Otherwise, you can't say that the photon emitters can be a reference. And the speed of light is independent of its source, so the movements of the photon emitters does not matter. (And as far as I know, there is no blue/red shift for a single photon) In short, there is no reference to detect your own movement in space, you always consider yourself at rest.
  • #59
you've got to be kidding!
that can't be the way it works. that's completely backwards thinking :D
are you telling me when they plan a mission to Mars they calculate that Mars is traveling closer, not the probe/lander/vehicle is traveling towards it? :|
  • #60
That looks equally valid to me, results of the calculations would be the same. But I guess you would normally plan a mission from a third frame's perspective (the earth).
  • · Replies 18 ·
  • · Replies 57 ·
  • · Replies 51 ·
  • · Replies 29 ·
