Calculating Pressure Drop Across Valve in Horizontal Pipe
The discussion focuses on calculating the pressure drop across a valve in a horizontal pipe with a steam flow rate of 0.5 kg/s. The inlet pressure is 5 bar (gauge) and the outlet pressure is 3 bar (gauge), with a mass quality of steam at 0.8. The participant successfully calculated the frictional pressure drop using the Lockhart-Martinelli correlation but sought clarification on the gravitational pressure drop term in the pressure drop equation. It was confirmed that for a horizontal pipe, the angle θ should be set to zero, negating the gravitational term in the equation.
  • Understanding of fluid dynamics principles
  • Familiarity with the Lockhart-Martinelli correlation
  • Knowledge of pressure drop equations in piping systems
  • Basic concepts of two-phase flow in steam systems
  • Study the derivation and application of the Lockhart-Martinelli correlation for two-phase flow
  • Learn about pressure drop calculations in different pipe orientations
  • Explore advanced fluid dynamics concepts related to phase change in steam systems
  • Investigate the impact of valve types on pressure drop in piping systems
Engineers, process designers, and anyone involved in the design and analysis of steam systems and fluid transport in horizontal piping configurations.
pray4mojo
Hi,
20m straight length horizontal pipe (60 mm internal diameter), steam flows at rate 0.5 kg/s, at midpoint there is a valve in the line. inlet pressure to this section of line is 5 bar (gauge), pressure at end of line is 3 bar (gauge). mass quality of steam is 0.8 and 2 phase flow occurs in the line.
I have calculated the mass flow of liquid and vapor in the line, the frictional pressure drop (N/m2) for the horizontal tube (without valve) using lockart martinelli correlation and also predicted the flow pattern at entry to the valve.
However,the part I am having a problem with is..When calculating the pressure drop across the valve.After calculating the homogeneous parameters and inserting them into the pressure drop equation which is: -dp/dz= [ρ*u *du/dz] + [2*f*ρ*u^2/d] + ρ*g*sinθ
First term in the equation i took equal to zero (no change in velocity assumed), but for the last term (ρ*g*sinθ), do i take theta(θ) as equal to zero as it is a horizontal pipe?
My solution is attached.
Thanks for any help!
Yes, you would take theta (θ) as equal to zero as the pipe is horizontal. The last term (ρ*g*sinθ) in the equation is the gravitational pressure drop which is only applicable when the pipe is not horizontal, i.e. when it has a vertical or inclined section.
