Orientation of coil in electric generator: Important?
The discussion revolves around the orientation of the coil in a simple electricity-generating windmill project. Participants explore whether changing the orientation of the coil affects the induced electromotive force (EMF) as it interacts with the magnetic field. The conversation includes practical considerations for design rather than theoretical efficiency.
  • Mark questions if rotating the coil 90 degrees will result in a greater EMF when it cuts the magnetic flux.
  • One participant suggests that the best orientation for a windmill generator typically involves multiple magnetic poles and stationary coils, indicating a preference for design considerations over theoretical orientation.
  • Mark expresses appreciation for the clarification regarding the orientation of magnets and coils, indicating that the information was helpful.
  • Another participant comments on the terminology used for "propeller," noting regional differences in English usage.
The discussion includes multiple viewpoints regarding the optimal orientation of the coil and the configuration of magnets and coils. No consensus is reached on the specific impact of coil orientation on EMF induction.
Participants mention practical aspects of design, such as the number of magnetic poles and the configuration of stationary versus rotating components, but do not resolve the implications of coil orientation on EMF induction.
Individuals interested in DIY renewable energy projects, particularly those exploring wind energy generation, may find the discussion relevant.
Antic_Hay
Hi, I'm working with my granddad on a project to build a (simple!) electricity generating windmill. We're not trying to make the most efficient design possible, just a reasonably efficient design given the simple tools and materials we're using. It's mostly just a project for fun! :)
So, we have a setup as in the diagram below. What I'm wondering, is does it make a difference what way the coil of wire is oriented, i.e. if it is rotated 90 degrees in some direction in the design, will a greater EMF be induced in it each time it cuts the magnetic flux of the magnet.
(To clarify, the coil is currently oriented so that additional windings will make it grow along the Y axis, looking down at the XY plane, the cross section of the coil will be circular)
(Please go easy on me if I'm saying anything moronic, it's been a while since I studied Physics is school, and I did very little of it in college! ;) )
(Oh, the final design will have a full radial array of coils and magnets, if that's any confusion! But my main question is what shape the coil should be !
Thanks!
Mark.edit: yep, I know that should be 'propellor', not propeller!
You have the best orientation for a windmill generator. Generally, the windmill generators have 8 to 12 magnetic poles (neodymium iron boron) in a circle, and as many coils for single phase output. But, unless you have a good way of getting the electric power off the rotor, you will want to have rotating magnets and stationary coils.
[Edit] I am not advertising this place, but here is a good detailed discussion of an axial field permanent magnet rotor construction for windmills. You should first decide on windmill blade diameter and expected windpower (watts and RPM)) and desired alternator power output.
http://www.otherpower.com/magnetrotors.shtml
Hey, that's great, that cleared things up totally, and that link was full of useful detail, thanks a lot :-)
You're right about the stationary magnets too, makes much more sense!
In the USA, "propeller" is fine. Of course, some English-speakers claim that we Yanks speak/write a debased version of the language. :wink:
18K
  • · Replies 42 ·
