If a man and a half can eat a cake and a half in a minute
  • Context: High School
  • Thread starter Thread starter ƒ(x)
The discussion revolves around a mathematical problem involving rates of consumption, specifically how many men would be needed to eat a certain number of cakes in a given time frame. Additionally, there is a separate problem concerning the volume of a sphere after removing a cylinder, which leads to further exploration of volume calculations and potential implications of radius on the results.
  • One participant suggests that if a man and a half can eat a cake and a half in a minute and a half, it leads to a calculation of how many men would be needed to eat 60 cakes in 30 minutes.
  • Another participant proposes that one cake can be eaten per minute per man, concluding that 2 men would suffice, while also humorously claiming half the prize money.
  • A different participant challenges the assumption of one cake per minute per man, providing a calculation that leads to the conclusion that 3 men would be needed instead.
  • Several participants introduce a new problem involving the removal of a cylinder from a sphere and discuss the implications of the radius on the volume calculation.
  • One participant asserts that the answer to the volume problem is independent of the radius, suggesting that as the radius of the sphere increases, the radius of the cylinder also increases, maintaining the volume percentage.
  • Another participant expresses confusion regarding the arrangement of the cylinder and its volume impact, questioning if there is a way to arrange it to occupy more volume.
  • Further contributions involve attempts to differentiate volume expressions to find optimal dimensions, with participants correcting their earlier calculations and exploring complex solutions.
Participants express differing views on the initial cake-eating problem, with no consensus on the number of men required. In the volume problem, there is also a lack of agreement on the implications of radius and the correctness of volume calculations, with multiple participants correcting or refining their earlier claims without reaching a definitive conclusion.
Some calculations and assumptions regarding the relationships between the number of men, cakes, and time are not fully resolved, and the implications of radius in the volume problem remain unclear. There are also unresolved mathematical steps in the differentiation process discussed.
ƒ(x)
If a man and a half can eat a cake and a half in a minute and a half, allowing the same situation, how many men would it take to eat 60 cakes in 30 minutes?
Btw, I'm getting these off an app on my phone.
Mathematics news on Phys.org
One cake per minute per man.
So, 2 men.
I want half the prize money.
Not quite-- If 1 man could eat 1 cake in 1 minute, then the one man in the example would've eaten 1 cake in 1 minute, while the other half-a-man would've eaten his half of a cake in 1 minute. So if it were 1 cake per minute per man, it'd be gone in 1 minute, rather than a minute and a half.
If R is the number of cakes per minute that 1 man can eat, then:
1.5 men * R * 1.5 minutes = 1.5 cakes
1.5 men * R minutes = 1 cakes
R = 1 cakes / (1.5 men minutes) = 2/3 cakes/men minutes
Hence, we now want:
Q men * 2/3 cakes/men minutes * 30 minutes = 60 cakes
Q men * 2/3 = 2 men
Q men = 3 men
Q = 3
DaveE
: faceplant :
I misread. I thought it was 1,1.5,1.5 not 1.5, 1.5, 1.5.
I have another one:
If you have a sphere and you remove a cylinder with a length of six inches from it (assume that the cylinder is arranged in such a way so as to go through the maximum amount of the sphere), what is the new volume?
ƒ(x) said:
I have another one:
Maybe I'm missing something-- I get:
2*pi*((2/3)*R^3-3*R^2-27)
(where R is the radius of the sphere.) I'm guessing that some factors are supposed to cancel out nicely?
DaveE
The answer is independent of radius because as the radius of the sphere increases the radius of the cylinder also increases, so the volume percentage remains the same. Kind of like why rain water depth is independent of the the volume used to measure it
I think there's some sort of stipulation that's being implied. Here's what I get using two extremely different values for the radius of the sphere (see attachment). Am I missing some way of arranging the cylinder such that it takes up more volume?
DaveE
DaveE
It looks like you've set the length to be >6 in the larger sphere, close to the diameter at 18 (?). Length is specified at 6, radius can vary
What about differentiating the expression for the volume difference to find the value of radius\diameter that minimises it?
So I get for the volume difference V = 4/3*pi*(d/2)^3 - 6*(d^2-36)*pi/4 where d is the diameter of the sphere, which upon differentiating and setting to zero gives either a diameter of 9 or -15. Using 9 gives the difference as 54*pi.
are we allowed complex solutions?
I'm not sure about complex solutions, but I just realized I factorised the quadratic wrong. I should have got a diameter of ~7.82 and a volume difference of ~43*pi.
Okay I've completely messed up that differentiation, I should've got d = 6 or 0 and that would maximise the volume difference so no good.
I've done nothing of the sort. The cylinder in the larger sphere resembles a disc: it's 6" tall, and extremely wide (big radius). The cylinder in the smaller sphere resembles a rod: it's also 6" tall, but is extremely narrow, in order to fit within the sphere. In both images, the circle is the sphere, and the rectangle is a sideways view of the cylinder, with the left and right sides being the straight "length" of the cylinder, and the top and bottom sides representing the diameter of the cylinder.
DaveE
DaveE
yes, I see, I didn't look carefully enough. I agree with your earlier analysis...I was remembering a strikingly similar problem in which the answer was a constant, not related to either radius
So to repeat arithmetix' question, are we allowed complex solutions? I get two possible complex ones: (45+i*9*(27)^1/2)*pi or (45-i*9*(27)^1/2)*pi (assuming I haven't made anymore silly mistakes, which is a big assumption :redface:).
  • · Replies 20 ·
