Finding Mu Without Friction Data
  • Thread starter Thread starter ConfusedPupil
    Data Friction
This discussion addresses the challenge of determining the coefficient of friction (mu) without direct friction data in a physics lab experiment involving inelastic collisions. The user seeks to utilize available variables such as mass, initial velocity, time in air, and displacement to derive mu. A suggested method involves using a known mass on cardboard to measure the force required to pull it across a surface, thereby allowing for the calculation of mu through the formula (0.259kg(vf-0m/s)/0.63s)/2.54N. This approach provides a practical solution for obtaining friction data indirectly.
  • Understanding of inelastic collision formulas
  • Familiarity with momentum equations
  • Basic knowledge of force measurement techniques
  • Ability to perform calculations involving mass and acceleration
  • Research methods for measuring friction using a force scale
  • Learn about the physics of inelastic collisions and momentum conservation
  • Explore techniques for calculating coefficients of friction experimentally
  • Investigate the use of elastic bands for force measurement in physics experiments
Physics students, educators conducting lab experiments, and anyone interested in experimental methods for calculating friction coefficients in mechanics.
ConfusedPupil
We are doing a lab nearly verbatim to the one at this link, http://dev.physicslab.org/Document.aspx?doctype=2&filename=Momentum_InelasticCollisionsSoftball.xml" However, under #6 in data and procedure I had forgotten to measure frictional force. Is there anyway to find mu or force of friction using the mass of the ball, initial velocity, time in air, distance thrown form box, mass of box and packaging, Fn, and box displacement?
Inelastic collision formula
momentum formulas
N/A stumped without formula to find mu or Ff, data not collected so I don't know how to work the real problem which I can do otherwise. Vf could also help me find Mu by using (0.259kg(vf-0m/s/0.63s))/2.54N = mu
You can find mu if you can take a bit of cardboard to a floor surface similar to the one you used in the experiment. Put any known mass on the cardboard and pull it along the floor with a force scale. If you can't get your hands on a scale, use an elastic band, measure its stretch, then find some way to achieve that same stretch with known forces. Likely you can look up the mass of coins and calculate their mg if no easier method comes to mind!
Thanks
  • · Replies 23 ·
22K
  • · Replies 34 ·
