What is the difference between synchronous and asynchronous motor?
The discussion centers around the differences between synchronous and asynchronous motors, exploring their operational principles, characteristics, and types. Participants examine the definitions and behaviors of these motors in relation to AC and DC power supplies.
  • One participant explains that a synchronous motor operates at a speed that is synchronized with the frequency of the AC voltage, providing examples of speeds based on the number of magnetic poles.
  • Another participant notes that asynchronous motors typically run slower than synchronous motors and that their speed can vary with mechanical load.
  • A participant describes induction motors as a type of asynchronous motor, highlighting that torque is generated through the interaction of the stator magnetic field and induced currents in the rotor, which requires the rotor to slip relative to the synchronous frequency.
  • There is a question raised about whether DC motors can be classified as asynchronous, with one participant suggesting that most DC motors are asynchronous due to the absence of a periodic time signal.
  • Further clarification is provided that while many DC motors are asynchronous, certain types, like stepping motors, are synchronous, and some brushless motors can be synchronized to an external clock.
Participants present differing views on the classification of DC motors, with some asserting that they can be asynchronous while others provide examples of synchronous types. The discussion remains unresolved regarding the categorization of DC motors.
There are limitations in the definitions provided, particularly regarding the classification of DC motors and the conditions under which different types of motors operate. The discussion does not resolve these ambiguities.
Individuals interested in electrical engineering, motor design, and applications of synchronous and asynchronous motors may find this discussion relevant.
samieee
hi all
i want to know What is the difference between synchronous and asynchronous motor?
thanks
A synchronous motor runs at a speed which is synchronised to the frequency of the AC voltage that supplies it. For example if the motor is supplied at a frequency of 60Hz then it will run at either 60, 30, 20 etc revs/second, depending on the number of magnetic poles (2, 4, 6 respectively) that it has (by design).
An asynchronous motor generally runs slower than the above with a speed that usually varies somewhat with the amount of mechanincal load that it is driving.
Induction motors are asynchronous because the motor torque is due to the stator magnetic field interacting with currents induced in the squirrel cage (of copper bus bars) in the rotor. In order to induce currents in the squirrel cage, the rotor has to slip with respect to the synchronous frequency. If you have never seen a squirrel cage, take a 1/4 HP induction motor apart and pull the rotor out.
Bob S
may dc motor can be asynchronous??
Most dc motors, including both brush motors (series connected, shunt connected, permanent magnet) and brushless motors are asynchronous, in part because there is no periodic time signal. There are many types of stepping motors that are inherently synchronous to a clock. Also, Hall-Effect sensor-type brushless motors can be synchronized to an external clock. Other dc motors can be controlled by feeding back an RPM signal to a controller.
Bob S
