How Can Four Circles Pass Through Two Points in a Plane?
  • Context: Undergrad
  • Thread starter Thread starter andlook
    Circles Points
The discussion revolves around the geometric problem of determining how many circles can pass through two specific points in a plane, specifically the origin and another point (a,b). Participants explore the conditions under which circles can be defined and the equations that represent them.
  • One participant asserts that there are four circles that can pass through the origin and the point (a,b), suggesting two circles with larger radii and two with smaller radii.
  • Another participant challenges this by stating that with three points (the origin and (a,b)), there can only be one circle if the points are not collinear, or none if they are.
  • Some participants clarify that there are indeed an infinite number of circles that can pass through two given points, not just four.
  • A method is proposed involving the construction of the perpendicular bisector of the line segment connecting the two points, where any point on this bisector can serve as the center of a circle that passes through both points.
  • A participant provides an example using specific coordinates to illustrate how to derive the equation of a circle passing through the two points.
  • Further clarification is made regarding the conditions under which circles can be defined, particularly emphasizing the role of the perpendicular bisector.
  • Another participant notes that the smallest circle that can pass through the two points has a diameter equal to the distance between them, while there is no maximum diameter.
  • There is a discussion about the generalization of the equations for circles passing through the points, including the derivation of the perpendicular bisector and its implications for circle centers.
Participants do not reach a consensus. There are competing views regarding the number of circles that can pass through the two points, with some asserting an infinite number and others suggesting a limited number based on the inclusion of the origin as a point.
Participants express uncertainty about the implications of collinearity among the points and the definitions of the circles being discussed. The discussion includes various assumptions about the nature of the points and the circles.
This discussion may be of interest to those studying geometry, particularly in understanding the properties of circles and their relationships to points in a plane.
andlook
Hey,
Given two points, the origin and (a,b) in R^2, I have convinced myself that there are four circles that pass through these points, two circles with larger radius so the arc is "shallower" and two with smaller radii with "longer" arcs joining the points. I am trying to calculate the equations of these circles. As it stands I think I have the equation of one:
I use (x-a)^2 + (y-b)^2 = r^2 and (x-0)^2 + (y-0)^2 = r^2
to get a^2 - 2ax = 2by-b^2
then sub in y = 0 to get x value.
I then use these two to get an expression for r^2.
Giving r^2 = (a^2-b^2)/2a
and hence
[x- (a^2-b^2)/2a]^2 + y^2 = (a^2-b^2)/2a
Can anyone let me know how to calculate the other circles, or suggest a strategy?
Maybe the two arcs of the smaller radii circles are the same circle...
I know that if I reflect the circle that I do have the equation for in the line joining (0,0) to(a,b) I will get the equation of one other, but what about the missing two? And which one have I got now?
Thanks
Mathematics news on Phys.org
I'm not sure I understand your question. You have 2 points and the origin? That's three points. As long as the 3 points are NOT colinear, then there exists only 1 circle that passes through them.
If you're saying that you have 2 points and a given radius, then there are exactly 2 circles that pass through the points.
If you're saying that given any 2 points, there exists 4 circles that pass through them, that is correct ... there ARE 4 circles that exist, but those 4 circles are not the only possible circles that pass through the points; there are an infinite number of circles that pass through them.
It sounds as if you're listing 3 objects:
1) & 2) "two points"
3) "the origin"
4) "(a,b) in R^2"
With regard to item 4, I don't know what you mean.
If you are listing 4 points, there is either 1 circle or no circle that passes through them.
hi to clarify,
I have the origin and the point x=a and y=b. No set radius. I want to join these by arcs of circles. How many circle arcs that join them? What are the equations of these circles? Or is this answered in previous reply?
Thanks
So, you're talking about 2 points:
A (0,0) and B (a,b)
There are an infinite number of circles that pass through them (not just 4).
There exist an infinite number of circles passing through two given points.
Construct the perpendicular bisector of the line segment between the two points. Choose any point on that line as center and take the radius to be the distance from that point to either of the original points. That circle passes through both points.
As an easy example, suppose the points are (0,0) and (0,b). The perpendicular bisector is the line y= b/2. Any point on that line is of the form (a,b/2). The distance from (a,b/2) to (0,0) is [itex]\sqrt{a^2+ b^2/4}[/itex]. The equation of such a circle is [itex](x-a)^2+ (y- b/2)^2= a^2+ b^2/4[/itex].
That is, any point on the perpendicular bisector EXCEPT for the point of intersection (which lies on the line segment between the 2 points and is therefore collinear).
The smallest circle that passes through 2 points has a diameter equal to the length of the line segment that connects the 2 points. There is no maximum diameter.
Disregard that statement ... I was thinking about non-collinear points lying on a single circle. Rather, HallsofIvy was stating that any point on the perpendicular bisector is the center of a circle passing through the other 2 points which, of course, is correct.
To generalize, for any point (a,b):
The slope of the line segment from (0,0) to (a,b) is:
[tex]\frac{\Delta Y}{\Delta X} = \frac{b-0}{a-0} = \frac{b}{a}[/tex]
The midpoint of the line segment would be at
[tex]\frac{a/2}{b/2}[/tex]
The perpendicular bisector of the line segment would be a line through the midpoint with slope [tex]\frac{-a}{b}[/tex]
The formula for the perpendicular bisector is then [tex]Y = \frac{-a}{b}X + \frac{a^2+b^2}{2b}[/tex]
Any point (c,d) on the perpendicular bisector is equidistant from both points. Therefore, there exists a circle with center (c,d) having a radius equal to the distance from (c,d) to the origin that also passes through (a,b). The radius would then be equal to [tex]\sqrt{c^2+d^2}[/tex]
The formula for all circles passing through the points (0,0) and (a,b) would then be [tex](x-a)^2+(y-b)^2=c^2+d^2[/tex]
