AC+DC signal equation=> Then Filter AC signal= output only DC signal visible
The discussion revolves around the challenge of removing an AC signal from a combined AC and DC signal. Participants explore various methods, including filtering techniques and circuit design considerations, while addressing specific voltage and frequency values.
  • Homework-related
  • One participant inquires about methods to filter out a 60V AC signal from a 50V DC signal, seeking C code or algorithms for implementation.
  • Another participant argues that completely filtering out a 60 Hz AC component may not be feasible due to the potential for amplifier overload, suggesting a capacitor to ground as a partial solution.
  • A subsequent post corrects the initial values, stating the AC signal is actually 5V at 1Hz and the DC signal is 12V.
  • Concerns are raised about the practicality of filtering a 1 Hz signal, with one participant noting that component values for such a filter could become large and expensive.
  • Further technical details are shared regarding the reactance of capacitors at low frequencies and the implications for circuit design, including calculations of output voltage with and without capacitors.
  • One participant expresses a need to calculate feedback resistance (Rf) in the presence of capacitance, seeking an equation that incorporates varying capacitance and resistance.
  • A reminder is issued that the discussion is part of a homework section, emphasizing a step-by-step approach rather than a single formula.
Participants express differing views on the feasibility of filtering out low-frequency AC signals, with some suggesting methods while others highlight significant challenges. The discussion remains unresolved regarding the best approach to achieve the desired filtering.
Limitations include the potential for amplifier overload with specific voltage gains, the impracticality of designing filters for very low frequencies, and the complexity of calculating feedback resistance in circuits with varying capacitance.
Individuals interested in circuit design, signal processing, and those working on related homework problems in electronics may find this discussion relevant.
What could be the best code in C to see the DC out put?
  • Lowpass filter
    Votes: 1 100.0%
  • FFT
    Votes: 0 0.0%
  • Total voters
sandhi
Dear friends,
I would like to know how can I remove an AC signal from a signal which is combination of AC+DC. AC signal 60V/50Hz DC=50V.
Please suggest me a C code or any algoritham or a filter which can remove AC signal completely and I should be able to see only DC signal in the out put.
with best regards,
Sandhi :(
You would not be able to filter out the 60 Hz component.
The AC input of 60 volts would overdrive the amplifier and the gain of 3.9 would make it worse if that was possible. The output would just be a 50 Hz square wave
If you had an input of 0.6 volts, it may be possible to reduce the AC component in the output, but not remove it completely. You could put a large capacitor to ground after the 10 K resistor.
Try 25 uF.
I am sorry to tell that I have mentioned wrong value. It is 5V/1Hz Ac signal and 12 V DC signal.
The 1 Hz signal would make things difficult, but there is a bigger problem.
12 volts DC into an amplifier with a gain of -3.9 will give an output of -46.8 volts.
Now, unless you have a supply of +/- 50 volts this is going to overload your amplifier.
Apart from that, filters for 1 Hz are not really practical. You can do calculations and design a filter, but the component values will become very large and expensive.
I would like to know how can I post a new thread with attachment? I don't see option where I can send a new post with attachment.
with best regards
prashant
Choose "new topic" at the top of the main page.
Fill in the template, if it is on the homework page.
When that opens go to the paperclip thing at the top of the edit screen.
Browse and find the attachment on your hard drive. Upload it.
Then put your cursor where you want the attachment to be. Go to the paperclip again and click on the name of the file you uploaded.
It will put a link to the attachment and you can see it if you go to "preview post" at the bottom of the edit screen.
This way, you can have various pictures or diagrams in the right place in your text.
Click on "submit new thread".
Thank you, I have found it. I have posted my new thread about origin of Capacitance formula.
Dear Sir,
I would like to know if you have received my mail few hours ago
Prashant Kumar
sandhi
Yes, I received your mail.
At 0.5 Hz, the capacitor has a reactance of 106103 ohms. The net impedance of the capacitor and resistor combination is 9.956 Kohms. So, really the capacitor has no effect.
In series with 1.01 Mohm, the output is 9.56 / 1010 or 0.00946 times the input voltage or 0.047 volts. Without the capacitor, it would be 0.0495 volts.
0.5 Hz is 1 cycle every 2 seconds. This is a very low frequency. What are you actually doing?
I am trying to calculate Rf by measuring the signal at Rm which I call it as Um. When there is no capacitance it is very simple to calculate Rf but with varying capacitance Ce and Rf I need to calculate du/dt to the signal measured at Rm i.e to Um volts. Um is almost like a squarewave.
Dear Sir, I would like to know the exact equation for Rf when I include capacitance Ce.
with regards,
Sandhi
This is the homework section, so the rules apply. This type of problem is solved by a process of steps, not really one formula.
You might like to have a look at this:
https://www.physicsforums.com/showthread.php?t=362836
It should tell you how to work out the impedance of a parallel RC network. You can add currents as vectors if they are flowing in the same wire, but you can't add impedances if they are in parallel.
You will also need to work out the reactance of a capacitor.
This is given by:
where F is in Hz and C is in Farads.
  • · Replies 39 ·
