How to Correctly Calculate R Thevenin in a Circuit Analysis?
  • Thread starter Thread starter TipTip
The discussion focuses on calculating the Thevenin resistance (R Thevenin) in a circuit analysis using a test voltage source. The original poster attempted to use mesh analysis with a 20V test voltage source but arrived at an incorrect value of 11.55 ohms instead of the correct 12 ohms. A suggestion was made to use the nodal method by selecting node b as the reference ground and injecting a test current of 1 amp into node a to simplify the calculation.
  • Understanding of Thevenin's Theorem
  • Familiarity with mesh analysis in circuit theory
  • Knowledge of nodal analysis techniques
  • Ability to interpret circuit schematics and identify nodes and meshes
  • Study Thevenin's Theorem and its applications in circuit analysis
  • Learn mesh analysis techniques and common pitfalls
  • Explore nodal analysis and its advantages over mesh analysis
  • Practice circuit problems involving test sources to reinforce understanding
Electrical engineering students, circuit designers, and anyone involved in circuit analysis seeking to improve their understanding of Thevenin resistance calculations.
TipTip
The question is find R Thevenien using Voltage test source across terminals a and b of the following circuit:
http://img255.imageshack.us/img255/8660/rthevenen.png
I did it by adding a 20 test voltage source and used mesh to get the following 4 equations of the 4 meshes ( I deactivated the 480 V independent source to be able to use test voltage method)
M1:6(x-t) + 40(x-y)+4x=0
M2: 40(y-x)+20=0
M3: 80(z-t) - 20q +2z-20=0
M4:4t + 8(t-z) +6(t-x)=0
q=x-t
I R thevenen to be 11.55 but actually the correct answer is 12 ohms.
Where is my mistake.
I don't see 4 meshes; I only see 3 meshes.
You need to explain in more detail what you are doing. What are x and y? I don't see anything labeled x and y on your schematic. You should tell me what they are, and don't expect me to figure it out for myself.
I would have used the nodal method, and select the node labeled b to be the reference (ground).
Then you can inject a test current of 1 amp into node a, and the voltage there will be equal to the Thevenin resistance (setting the 480 volt source to zero, of course).
  • · Replies 21 ·
  • · Replies 41 ·
9K
