Recursive Palindrome Check in Java: An Efficient Solution
  • Context: Java
  • Thread starter Thread starter Pattielli
The discussion focuses on implementing a recursive function in Java to check if a given string is a palindrome. The function utilizes two arguments, 'a' and 'b', representing the indices of the first and last characters of the string. It compares these characters and recursively calls itself with updated indices until it confirms the palindrome condition or determines that the string is not a palindrome. The solution effectively handles both odd and even-length palindromes by checking specific conditions during the recursion.
  • Java programming language
  • Understanding of recursion
  • String manipulation techniques in Java
  • Basic knowledge of conditional statements
  • Implement and test the recursive palindrome function in Java
  • Explore Java String methods for enhanced string manipulation
  • Learn about stack memory and recursion depth in Java
  • Investigate iterative approaches to palindrome checking for performance comparison
Java developers, computer science students, and anyone interested in algorithm design and recursion techniques.
Pattielli
Would you tell me how to write a test_function to check a given string whether it is a palindrome or not in Java recursively ?
Thank you,
-Pattielli
Technology news on Phys.org
The initial condition of the recursion is that the function is checking the first and last characters to see if they're the same. In other words, the recursive function is called with two arguments: (0, string.length() - 1). I will call those arguments a and b.
The function checks the two characters at the positions (a and b) given by the arguments. If they are not the same, the function return false.
If they are the same, the function first checks to see if it has met the condition to complete the check. If a and b are the same number, the recursion has reached the center of an odd-length palindrome. If b is one greater than a, then the recursion has reached the center of an even-length palindrome. If either of these conditions is true, the function returns true. If these conditions are not true, the check is not complete yet, and the function calls itself with arguments (a+1, b-1), and returns whatever result that call returns.
- Warren
Many Thanks to Warren, I understand and made my program work fine as what you told me, Thanks a lot,
- Pattielli
  • · Replies 16 ·
