How to Calculate the Volume of the Earth Using Scientific Notation
  • Context: High School
  • Thread starter Thread starter BogMonkey
    Earth Volume
The discussion revolves around calculating the volume of the Earth using the mean radius of 6371 km, specifically focusing on the use of scientific notation and unit conversion in the calculation process. Participants explore the implications of these methods on the accuracy of the final result.
  • Homework-related
  • One participant describes their approach to calculating the volume using the formula \( \frac{4}{3} \pi r^3 \) but encounters discrepancies in the final answer due to unit conversion issues.
  • Another participant emphasizes that using scientific notation does not change the result but highlights the importance of showing the final answer for clarity.
  • A participant reveals their final answer and the correct answer, recognizing their mistake in unit conversion when calculating the volume.
  • There is a suggestion that converting to SI units from the start is essential to avoid errors, with one participant asserting that it should be a standard practice for beginners.
Participants generally agree on the importance of unit conversion and the use of SI units, but there is no consensus on the best approach to teaching or learning these concepts, as some advocate for strict adherence to SI while others suggest flexibility with experience.
Limitations include the potential misunderstanding of scientific notation and the implications of unit conversion on the final calculation, which remain unresolved in the discussion.
BogMonkey
I got this question on a multiple choice test and I couldn't do it. The question was
"Calculate the volume of the Earth knowing that the mean radius is 6371 km."
What I did was multiply 4*pi*6371^3 then divided the answer by 3 but it didn't yield the correct answer. I got the solutions sheet for the test and here's how the teacher solved the problem
= 4pi * (6.371 * 10^3)^3 / 3
= 4pi * (6.371)^3 * 10^9 / 3
They're the first two steps of his solution but I'm completely lost. How do you magically get a different answer by using scientific notation? I know the laws of indices but I don't understand how I got a different answer because I didn't use scientific notation to represent 6371 km.
Since you have not shown us your final answer there is no way we can point you in the right direction. You are correct using scientific notation will not change the result.
Sorry here's my answer:
1.08 * 10^15 m^3
heres the correct answer:
1.1 * 10^23 m^3
What I put into my calculator was this 4pi(6371^3) / 3 then to convert to meters I multiplied by 1000. Ah right now I see my mistake. 6371^3 * 1000 is not the same as 6371000^3. I suppose a good rule of thumb to follow is to convert to the appropriate units from the start.
No, it is not just a good rule of thumb: For "beginner" it is a rule. You should always convert all values to SI before you plug them into an equation.
Once you get more used to the equations you are working with you can start "cheating" a bit, but the "default" should always be to use SI for everything.
That is the best way to avoid making errors.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 24 ·
