V-Shaped Pendulum Help - Formula & Analysis
  • Context: Undergrad
  • Thread starter Thread starter PhysicsLearne
    Pendulum
The discussion centers on the analysis of a V-shaped pendulum, specifically examining the formula for its period, T = 2π√(L/g), where L is derived from the Pythagorean theorem as L = s² - 0.25d². The participants confirm that this formula is valid for the experiment conducted, where the hypotenuse distance 's' remains constant while the vertical distance 'd' varies. Additionally, the discussion highlights that the V-shaped pendulum behaves similarly to a traditional pendulum in terms of potential energy and velocity, making it a suitable model for various applications.
  • Understanding of pendulum motion and periodicity
  • Familiarity with Pythagorean theorem applications
  • Knowledge of conservation of energy principles
  • Basic grasp of gravitational acceleration (g)
  • Research the effects of varying 'd' on the period of a V-shaped pendulum
  • Explore the implications of Foucault pendulum precession on pendulum motion
  • Study the energy conservation in oscillatory systems
  • Investigate applications of V-shaped pendulums in engineering and physics
Students and researchers in physics, particularly those focusing on mechanics and oscillatory motion, as well as educators developing curriculum on pendulum dynamics.
PhysicsLearne
Hey there,
Basically we had an experiment where we had to change the distance 'd' on a v shaped pendulum (0.5d for each side of the V)..where the value 's' which is the hypotenuse distance of the V stayed constant but the vertical distance changed.
does the following formula hold:- we know T = 2pi√L/g
now for this experiment using pythagorus' theorem we can find that L = s^2 - 0.25d^2
which gives T = 2pi√√s^2 - 0.25d^2 / g
is this correct and does the equation hold.
also what other things can i talk about to analyse V-shaped pendulums in particular, I have to write a long essay on it. and was wondering what else i could say the experiment.
Thanks a lot
If you look along the line joining the 2 end points of the "V", you can see that the locus of the weight is no different from that of a typical pendulum with length L. At every corresponding point the potential energy of the weight is the same in either type. By conservation of energy, the velocity of the weight must also be the same. So the two types behave the same and your work looks good to me.
The V-shaped pendulum confines the periodic motion in only one plane which may be convenient for most applications. A typical pendulum's plane of motion depends on initial conditions and changes over time due to Foucault pendulum precession. If started improperly, the latter can be set to swing in a vertical plane while circling in a horizontal plane at the same time.
Wai Wong
10K
