Who knows the proper name for this experiment
  • Context: Undergrad
  • Thread starter Thread starter rimblock
    Experiment
The discussion centers around an experiment involving a motor that requires less energy to restart after being stopped, with references to concepts like 'magnetic-sensitive ether' and residual magnetism. Participants explore the implications of these ideas and seek the proper name for the experiment, touching on themes of pseudoscience and experimental validity.
  • One participant describes an experiment where a motor, after being spun to high speeds and then stopped, requires less energy to restart if done within a short time frame, suggesting a rotating field that retains momentum.
  • Another participant proposes that any difference in restart energy could be attributed to residual magnetism or the coefficient of friction in bearings, expressing interest in actual experimental results.
  • A later reply questions the validity of the experiment, labeling it as a "hoax" or "pseudoscience," depending on the experimenter's awareness of their conclusions.
  • Some participants express skepticism about the existence of a luminiferous aether and its ability to carry momentum, suggesting that the search for the experiment's name may be misguided.
  • One participant insists they have encountered multiple articles supporting the energy-saving claim, despite the skepticism expressed by others.
Participants do not reach a consensus on the name of the experiment or its validity. There are competing views regarding the nature of the experiment, with some defending its legitimacy while others dismiss it as pseudoscience or a hoax.
Participants express uncertainty about the experiment's name and the mechanisms involved, with some acknowledging potential errors in experimental design or interpretation. The discussion reflects a range of assumptions about the underlying physics and the credibility of sources.
rimblock
Hi,
I read about an experiment in which less energy than expected was required to restart a motor that had already been spinning. The explanation i read indicated that there was some sort of 'magnetic-sensitive ether' that continued to rotate after the motor had stopped, meaning that restarting it in the same direction could take advantage of the ether's momentum.
Your wisdom is greatly appreciated :-)
You'll get more replies if you clarify your question...
Ok i'll give it another shot!
I read about an experiment in which a motor was speed up to a high speed, then forced to stop. If the motor was then restarted within, say, 30 seconds, the amount of energy required to get the motor up to full speed was less than when it was first brought up to full speed.
The article metioned that some sort of rotating field that continued to move, eventhough the motor was stationary (as if the field had its own momentum that was loosely coupled to the rotational motion of the motor).
What is the name of this experiment?
thanks again.
thanks again.
Someone must know!
I'm not sure of the name of the experiment in question, but I would have to assume any difference in restart amperage would be due to residual magnetism. Possibly the coefficient of friction of warm bearings vs. cold ones too. I'd be interested in the actual experimental results if you ever find them. I have to assume it is a very small difference.
Somebody must know! I'm sure i wasn't sleep reading..!
The correct name for the experiment is "hoax" if the experimenter knows his conclusions are wrong or "pseudoscience" if the experimenter believes his conclusions and simply performed a bad experiment.
Seriously, not a hoax afaik. I wish i could remember the name. That said if there are any genies reading this, i have other priorties so PM me.
Anyone?
I have been looking for days now!
I am sure it wasn't a hoax because i found other articles describing the same effect.
Then it is pseudoscience and they are not carefully controlling their sources of experimental errors. There is no reputable evidence for a luminiferous aether, let alone one that can carry momentum.
Give up this pointless search and apply your time to learning some real science instead. Whether it is a hoax or pseudoscience, either way you are chasing a fairy tale.
Hey, thanks for your response. Congrats on 4000 posts too!
I looked up 'luminiferous aether motor' on google and couldn't find any reference to the experiment i described. Perhaps my explanation is incorrect(!), but i am sure i read a few articles that supported the same result ... 'that a motor restarted before a certain time required less energy to reach full speed'. Aether aside, does this result ring any bells? The energy saving was definitely not down to warm bearings or any other obvious reason.
Also, i was only asking for the name of an experiment. Failing to answer my question, accompanied with a short lecture telling me i need to learn some 'real science', when you know nothing about me (or the experiment i was referring to), kind of makes me think you are prone to missing important information and making rash assumptions.
Cheers.
  • · Replies 42 ·
