Will the Moon escape Earth's orbit in billions of years?
The discussion centers around the long-term fate of the Moon's orbit around the Earth, specifically whether it will eventually escape Earth's gravitational influence. Participants explore concepts related to orbital mechanics, tidal interactions, and the implications of these phenomena over billions of years.
  • Some participants assert that the Moon is gradually moving away from Earth and will reach an orbital resonance in about 50 billion years, where the Earth's rotation period matches the Moon's orbital period.
  • Others argue that after reaching this resonance, the Moon could theoretically move closer to Earth, but this scenario is complicated by the eventual consumption of both bodies by the Sun.
  • One participant highlights the role of Earth's non-spherical shape and tidal bulges, explaining how these factors contribute to the Moon's gradual recession and the transfer of angular momentum from Earth to the Moon.
  • Another participant emphasizes the complexity of tidal interactions, noting that while the Moon currently recedes, future interactions with solar tides could lead to a lower orbit for the Moon.
  • Several participants express a desire for clarification on the concept of resonance and its implications for the Moon's orbit, indicating a lack of understanding of the underlying mechanics.
Participants generally agree on the mechanics of tidal interactions affecting the Moon's orbit, but there is disagreement regarding the long-term outcomes, particularly whether the Moon will escape Earth's orbit or move closer after reaching resonance. The discussion remains unresolved on these points.
Participants mention the long timescales involved, with some noting that the 50 billion years required for resonance exceeds the current age of the universe. There is also acknowledgment of the complexities involved in orbital mechanics and tidal effects, which may not be fully understood by all participants.
This discussion may be of interest to those studying astrophysics, orbital mechanics, or anyone curious about the long-term dynamics of celestial bodies and their interactions.
Richard87
I've heard that the moon is very slowly moving away from Earth. Will it eventually escape Earth's orbit?
Astronomy news on Phys.org
No, the moon will only move away from Earth until it reaches an orbital resonance when the length of the Earth's day and the Moon's month will be equal - that's in about 50bn years.
In theory the moon could then move closer to Earth, but since they are both going to be consumed by the sun before that - it's a bit academic.
It would also be worth mentioning that the 50 billion years it would take for this to happen is longer than the current age of the universe.
Could you please shed some light on this assertion?
You involved something like "resonance", knowing only resonance in circuits, I think about it as the time where the Moon is the farther from the Earth. But I don't understand why it would then come closer to it, considering tides effects, i.e. some "loss" of gravitational energy in detriment to friction. Feel free to correct me if I said something wrong. My goal is to learn.
The Earth isn't a perfect sphere, it has bulges around the equator (and the moveable water in the oceans) this means that the moon doesn't simply go around a point. it feels a stronger pull from one side of the Earth than the other, ie from the nearer bulge.
The effect of this is to slow the Earth's spin slightly and transfer this angular momentum into the moon, which makes the moon move further away.
Eventually enough of the Earth's spin will have been transferred and the moon will have moved far enough away that it's month (it's orbit around the earth) and the Earth's rotation are the same.
At this point the bulges on each side of Earth are at the same distance and no longer have any effect.
Now any angular momentum that is lost from the system, to interactions with passing comets, or the other planets will decrease the moons distance.
ps. Orbital mechanics , especially tidal effects, are complicated and not very interesting/useful plusit's long time since I had to learn any of this junk, so someone else could probably explain it better !
Thank you very much. I should sharpen a bit more my English. I've understood something, I just hope it's what you mean.
By the way, it might look like something uninteresting to you, but I assure you that not knowing what really happens is frustrating and makes your curiosity growing! So I don't find this uninteresting. :biggrin:
The concept is interesting, it's just all the equations you have to learn, and the complications of the reference frames and which angles are measured from where, and so on that is tedious.
The wiki article on lunar orbit is a good starting point.
It is tidal interaction that causes the Moon to recede. The Moon raises tidal bulges on the Earth. Friction between the bulges and the rotating Earth drag the tidal bulges out of alignment with the Moon. The out of line bulges pull forward on the Moon, giving it more energy which lifts it into a higher orbit. The Earth slows its rotation in response.
This all happens because the Earth rotates faster than the Moon orbits. So when the Earth slows enough to match its rotation rate to the Moon's orbit, the situation stabilizes.
However, the Sun still raises tidal bulges on the Earth, which continue to slow the Earth's rotation. Now the Earth is rotating slower than the Moon orbits. Again, friction between the lunar tidal bulges and the Earth come into play. This time however, the bulges lag behind the Moon, pulling it backward, and into a lower orbit.
This interplay between Solar and Lunar tides will continue forcing the Moon into a lower and lower orbit.
Thanks. Very nice explanation, I get it.
  • · Replies 0 ·
  • · Replies 58 ·
  • · Replies 24 ·
