Law of conservation of mass question
The discussion centers on the Law of Conservation of Mass, which states that matter cannot be created or destroyed in a chemical reaction. It highlights the transition from mass conservation to mass and energy conservation, particularly in nuclear reactions. The concept of "unburning" is explored, specifically regarding calx, a metal oxide that can be reduced back to metal through a reaction with charcoal, producing carbon monoxide. This reduction process has been utilized for thousands of years in metallurgy.
  • Understanding of the Law of Conservation of Mass
  • Basic knowledge of chemical reactions and oxidation-reduction processes
  • Familiarity with calx and its role in metallurgy
  • Awareness of mass-energy equivalence in nuclear chemistry
  • Research the principles of oxidation and reduction in chemistry
  • Study the process of metal extraction from ores
  • Explore the concept of mass-energy conservation in nuclear reactions
  • Learn about the historical methods of metallurgy and their chemical foundations
Chemistry students, educators, metallurgists, and anyone interested in the principles of chemical reactions and material transformation.
land_of_ice
" In a chemical reaction matter can be neither created nor destroyed "
So does this law only apply to chemical reactions or can matter ever be destroyed or created in any way shape or form?
and do people believe that something that has been burned can be unburned?
It says that when metal is heated it leaves behind calx and that if you want to remove the calx and combine it with charcoal you can then heat the calx will become metal again, this seems untrue, this is in a science book, not sure whether or not they are talking about a theory that existed at one time or if this is believed to be true now a days that something can be un burned ?
Chemistry news on Phys.org
Mass conservation has been replaced by mass&energy conservation - that is, mass can be converted directly into energy and vice versa. But for most practical purposes mass conservation still holds, it becomes important when you are close to c or when you are talking about nuclear eactions.
Calx is usually a metal oxide - and it can be decomposed back into metal and oxygen. It doesn't have to be easy, but it is always doable.
This is called reduction (the opposite of oxidation). The heated charcoal produces carbon monoxide, which steals the oxygen from the metal oxide, turning it back into metal again.
It's how people have produced metal from ore for ten thousand years.
  • · Replies 22 ·
  • · Replies 19 ·
11K
