What Is the Acceleration of the Bottom Point of a Rolling Object?
The discussion revolves around the acceleration of the bottom point of a rolling object, specifically addressing the scenario where this point is instantaneously at rest. Participants explore the implications of this condition in relation to angular and linear acceleration.
  • Conceptual clarification, Assumption checking, Mixed
  • Some participants attempt to apply the formula a = αr, questioning its relevance when the point is at rest. Others raise concerns about the implications of instantaneous rest on acceleration.
The discussion is ongoing, with participants expressing differing views on whether the acceleration of the point at rest can be considered zero. Some provide reasoning based on reference frames, while others question the assumptions underlying the problem.
There is a focus on the inertial frame of reference and the relationship between the center of mass and the point of contact. Participants are examining the definitions and implications of acceleration in this context.
jumbogala
The point on the bottom of a rolling object is instantaneously at rest (v = 0).
What is the acceleration of that point?
The formula given is a = [tex]\alpha[/tex]r, and r = 0. So I'm guessing it's zero as well, although that doesn't seem to make logical sense. Can anyone confirm that the answer is indeed zero?
(By the way, the equation for v = [tex]\omega[/tex]r, and in this case r = 0. So r has to be zero for the equation for a as well.
Confirmed instantaneously, zero. The entire wheel accelerates instantaneously relative to the point of contact. The point of contact is the only point on the wheel that is at rest with respect to an inertial frame, namely the floor.
Just because the point of contact is instantaneously at rest does not mean its acceleration is zero.
Seems like I'm getting conflicting answers...
If that's wrong, then how does the formula a = αr work in this case? I know in general that formula is useful for "converting" angular acceleration to linear acceleration, but how does it pertain to the bottom of a rolling object?
I'd say that that formula won't help much here. It would tell you the tangential acceleration of some point with respect to the axis, but what's the angular acceleration in this case? Either way, it doesn't give the acceleration of the axis itself.
To find the acceleration of a point on the rim, consider the motion of that point with respect to the center of mass.
Why the center of mass? Isn't the axis in this case the bottom of the wheel?
For one thing, we know its acceleration. Presumably the object is rolling at constant speed, so the acceleration of the center of mass is zero.
Yes, the bottom of the wheel is the instantaneous axis of rotation. But we are trying to find the acceleration of that point, not of some other point about that axis.
And you didn't answer my question: What's the angular acceleration of this rolling object? :wink:
I agree, but in this case I think it does. The problem states
It is implicit in that statement, that the reference frame, with respect to which the velocity is zero, is the inertial frame of the surface on which the object rolls. There is no other frame in which v = 0. The center of mass may do whatever it wants, but in the inertial frame of the surface (instantaneously), the acceleration of the point of contact is zero and its velocity is also zero.
(1) If the velocity and acceleration are both zero, how does it move?
(2) The acceleration is the same in any inertial frame, including the one in which the center of mass is at rest. Of course, from the center of mass frame it is easy to see that that point of contact is accelerating.
kuruman said:
But in the inertial frame of the surface (instantaneously), the acceleration of the point of contact is zero and its velocity is also zero.
I would say one component of the acceleration is zero, and I think this is true regardless of whether the center of mass is accelerating or not.
Absolutely.
Of course. I set my priorities wrong when thinking about this.
  • · Replies 35 ·
  • · Replies 42 ·
  • · Replies 97 ·
  • · Replies 65 ·
  • · Replies 17 ·
