collinsmark
Homework Helper
- 3,446
- 3,674
stewartcs said:Again, I'm not saying work is being done on the spring. I'm saying that the electric motor will consume energy with a locked shaft. The energy consumed is converted to heat and dissipated from the windings (which will eventual burn up with a locked shaft).
Energy is only dissipated as heat in the motor, if the motor is less than 100% efficient.
If the motor is 100% efficient, then by definition, all energy input into the motor is converted to work (are you using a different definition of efficiency?). If such a motor does not do any work, it takes in 0 J of energy.
Take an electric motor, connect a spring to the shaft and then the anchor one end of the spring. Now apply a voltage to the terminals of the motor. What happens?
[Edit: What I mean here is what happens after the system reaches steady state. Or alternatively, if you just locked the shaft down directly.]
If the motor is 100% efficient, nothing. The terminals behave as an open circuit and no current flows.
This (hypothetical) 100% efficient motor will produce a torque however. Ignoring any momentary stress in the mechanics (which is reasonable to ignore since we're discussing things that are 100% ideal anyway) this torque is fully counteracted by the normal force of the locking mechanism on the shaft. Torque is applied, but no angular displacement -- meaning no work is done. Similarly, an electrical potential is applied, but no current is drawn, therefore no power is consumed.
The shaft of the motor is now locked and is not moving, the spring is stretched (contains potential energy) and the current in the armature is still present (but a lot higher) as well as the voltage on the terminals...hence power is being supplied to the motor which means energy is being used (i.e. converted to heat in this case).
Yes, this is quite true for motors operating at less than 100% efficiency. But if the motor's efficiency is at 100%, no electric power flows into the motor, even if a voltage is applied to the terminals.
I've personally verified this with lab tests before and have actually seen the input power go up dramatically when the shaft became locked. It went up dramatically due to the armature current increasing dramatically which was a direct result of the locked shaft.
Yes, so have I!
In other words, when you're running this (locked shaft) test you are testing with a motor that is operating at 0% efficiency.
Again, as I've said all along, their is no work being done on the brick or spring or whatever object you want to put in its place. But the electric machine is still using energy (i.e. power) while holding the spring in place (i.e. locked shaft).
Yes, but only true for motors having less than 100% efficiency. The same applies for human waiters and weightlifters.
