Lagrange error bound to estimate sin4° to five decimal places( maclaurin series)
hangainlover
Estimate sin4 accurate to five decimal places (using maclaurin series of sin)
4°=pi/45 radians
|Rn(pi/45)<1*(pi/45)^n+1/(n+1)! < 5*10^-6
and the answer key says n should be greater than or equal to 3.
It doesn't make sense .
Because, if you write out derivatives, the ones with sines will disappear in the polynomial. So, don't we have to ignore sin (since it is maclaurin series)
So if it is 7rd order polynomial it should be x-(1/3!)x^3 + (x^5)/5!) -(x^7)/7!.
and therefore we need to look at 9th derivative.
It seems the answer key just applied the remainder theorem.
Plus why do they say that the remainder should be less than or equal to .000005
I think it is due to the fact that the questions says it should be accurate to five decimal places.
but what about .000009 or something?
they are still less than .00001
i think in this case our error bound inequality should be
1*(pi/45)^(2n+3)/(2n+3)! greater than or equal to .000005
and i get n=1 which means i only need the first two terms in the maclurin series to have a value accurate to the fifth decimal place.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
