Using Gauss's law to determine elctric fields (Calculus based problem)
A sphere of radius R with total charge +Q is surrounded by a thick spherical shell with inner radius R and outer radius 2R, carrying a total charge of -Q. To determine the electric field in different regions using Gauss's law, one must first establish a Gaussian surface, typically a concentric sphere. For the region 0 <= r <= R, the enclosed charge can be calculated based on the volume charge density. In the region R <= r <= 2R, the net charge enclosed will be zero, leading to a specific electric field behavior. Understanding the steps to apply Gauss's law effectively is crucial for solving this problem.
camrylx
A sphere of radius R has a total charge +Q, uniformly distributed throughout its volume. It is surrounded by a thick spherical shell of inner radius R and outer radius 2R carrying a total charge -Q, also uniformly distributed throughout its volume. Using Gauss's law, determine the electric field as a function of r, the distance from the center of the sphere for the regions:
1. 0<=r<=R
2. R<=r<=2R
3. r>=2R
Gauss's Law but from there no idea
How do you use Gauss's Law? What is the first step? Look in your textbook to get an idea if you have none.
Ok like I know the formula I have a good picture draw but not sure how to tackle this problem... And by the way the idea of looking in the textbook to get started would be great if there was a textbook... Feel free to recommend one because I'm on my own with that
Ok the Gaussian surface would be a small sphere inside a different sphere. I know where +Q and -Q and i know how to find the \sigma and all of that stuff. I know to start with q'=(r^3/R^3)*q and integrate that from 0 to 2pi and i think the 2 radius or something from there. I know coulombs law will come into and will be working this a spherical charge distribution and do some other stuff from there. I've seen a similar problem but I am not sure how to fill all of the details in and I struggle with deriving some problems.
OK, Let's start with region 1, r < R. Can you describe the Gaussian surface you will need to find the E field? Fill in the blanks:
It is a sphere of radius _____ centered at _____ .
Then can you find the total electric flux through this sphere?
Finally, can you find the total charge enclosed by this sphere?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
