Can an Induction Motor be Used as a Generator for a Micro-Hydro Power System?
  • Thread starter Thread starter VooDoo
    Design Micro
This discussion focuses on the feasibility of using an induction motor as a generator in a micro-hydro power system. It confirms that an induction motor operates as a generator when its speed exceeds the rated speed, such as 1600 RPM for a motor rated at 1500 RPM. The conversation highlights the importance of synchronizing voltage, phase, and frequency with the grid to prevent damage. Additionally, it raises concerns about the generator's behavior during grid disconnection and suggests researching doubly-fed induction generators (DFIG) for potential applications.
  • Understanding of induction motors and their operational principles
  • Knowledge of grid synchronization requirements for generators
  • Familiarity with power angle concepts in electric machines
  • Basic principles of micro-hydro power systems
  • Research "motor to generator transition" in electric machines
  • Investigate the specifications and applications of doubly-fed induction generators (DFIG)
  • Learn about grid synchronization techniques for renewable energy systems
  • Explore the mechanical design considerations for micro-hydro turbines
Engineers and hobbyists interested in renewable energy solutions, particularly those looking to implement micro-hydro power systems using induction motors as generators.
VooDoo
Looking into “reverse engineering” a pump and running it like a turbine and using an induction motor of some sort generate power. Basically design/build my own micro-hydro power system. The system if I do go ahead with it, will be connected to the grid.
I am very capable of handling the mechanical side of things, however I have a lot of reading to do when it comes to the electrical side. From what I have read so far I need an asynchronous generator (or induction motor).
I will list my questions, it makes it much easier to read:
1. From what I have read, I understand if the induction motor spins above the rated motor speed it becomes a generator, anything below the motors rated speed and it becomes a motor. Is this correct?
2. Suppose the motors rated speed is 1500rpm, and I design my turbine to spin at 1600rpm and connected it to the motor, will it begin to generate power and automatically synchronise to the gird? What happens if there is a sudden increase in flow rate and the turbine spins up to 1950rpm what would happen to the generator, would it continue to produce power and synchronise to the grid? Is there a maximum speed the generator can handle? I know for a synchronous generator I can use that formula to calculate synchronous speed (depends on number of poles and grid frequency), is there a certain percentage of this that should not be exceeded by an asynchronous generator for example the turbine speed should not go higher than 10% of the synchronous speed?
3. What happens if the generator is happily generating and is suddenly cut off from the grid? For example it is turning at 1600rpm and then suddenly it is disconnected from the grid, it is turning too fast to be a motor. Or if there is a spike or instability in the grid?
4. I was told to look into a doubly-fed induction generator, (DFIG). Would a DFIG system suite my application? I have tried searching for DFIG manufacturers and couldn’t find anything, are there any companies that sell complete DFIG units? Are prices substantially more expensive than that of an asynchronous generator?
Thanks for any help in advance, I understand I have a lot of reading to do!
Apologies, just realized I posted this in the wrong section, was ment to go in electrical.
The power angle will determine if the electric machine operates as a motor or generator. Essentially if you have a motor and its shaft spins faster than its rated speed it will change the power angle and cause it to back-feed the source (grid in this case). However, if no electrical power is being applied to the motor and you rotate the shaft, the motor becomes a generator and will provide an electrical power output.
If you are completely powering the electric machine via a mechanical source then you have a generator. To connect it to the grid the voltage, phase, and frequency must be within a certain tolerance or you'll have a big problem. If it is out of phase enough then it will damage your prime mover. If the machine is already connected to the grid and acting as a motor and you speed up the shaft so that the power angle changes (I forget off the top of my head which way) then it can start to provide power to the grid. However, you'll still have a big problem since your little generator won't load share properly with the grid (essentially an infinite bus).
If you somehow managed to load share with the grid and then disconnected your generator, nothing would happen other than the generator would be running at no load. The point you need to be aware of is that an electric machine will operate as a motor or generator depending on the power angle (which depends on the electrical load and mechanical load). If the electrical power input is higher the machine will act as a motor, if the mechanical input power is higher, it will act as generator.
Research "motor to generator transition" to find out more information. Most books on electric machines will have a section on this.
I'm not familiar with DFIG's.
Hope this helps.
CS
  • · Replies 51 ·
  • · Replies 46 ·
