Why does e^{-0.5} equal \sum_{n=0}^\infty \frac{(-1)^n}{n!}(0.5)^n?
  • Thread starter Thread starter nhrock3
    Error Exponent
The discussion revolves around the mathematical expression for calculating \( e^{-0.5} \) and its representation as a Taylor series. Participants are exploring the relationship between the exponential function and its series expansion.
  • Conceptual clarification, Mathematical reasoning
  • The original poster questions why \( e^{-x} \) is developed with \( 0.5 \) instead of using \( e^{+x} \) with \( -0.5 \). Other participants discuss the Taylor series representation and the differences between the series for \( e^{-x} \) and \( e^{x} \).
Some participants have provided insights into the Taylor series for \( e^{-x} \) and how it leads to the expression for \( e^{-0.5} \). There is an ongoing exploration of the equivalence of different series representations, but no consensus has been reached on the original poster's question.
Participants are navigating the nuances of Taylor series and the implications of using different forms of the exponential function. There may be assumptions about familiarity with series expansions and derivatives that are not explicitly stated.
nhrock3
i need to calculate [tex]e^{-0.5}[/tex]
why the solution develops [tex]e^{-x}[/tex] and puts 0.5
and not [tex]e^{+x}[/tex] and putting -0.5
I have no idea what you are talking about. What do you mean by "develops [itex]e^{-x}[/itex]? Writing as a Taylor's series? Approximating by the tangent line?
I suspect that both them method your book gives and your method would give the same answer. Have you tried it?
yes developing in taylor series
but in the first we have libnits series and on the other not
so its not the same
why they are not the same?
If [itex]f(x)= e^{-x}[/itex] then f(0)= 1, [itex]f'= -e^{-x}[/itex] so f'(0)= -1, [itex]f"(0)= e^{-x}[/itex] so f"(0)= 1, etc. The "nth" derivative, evaluated at x= 0, is 1 if n is even, -1 if n is odd. The Taylor's series, about x= 0, for [itex]e^{-x}[/itex] is
[tex]\sum_{n=0}^\infty \frac{(-1)^n}{n!}x^n[/itex].<br /> <br /> In particular, <br /> [tex]e^{-0.5}= \sum_{n=0}^\infty \frac{(-1)^n}{n!}(0.5)^n[/itex]<br /> <br /> The usual Taylor's series for [itex]e^x[/itex] is, of course, <br /> [tex]\sum_{n=0}^\infty \frac{1}{n!}x^n[/itex] <br /> <br /> and now<br /> [tex]e^{-0.5)= \sum_{n=0}^\infty \frac{1}{n!}(-0.5)^n= \sum_{n=0}^\infty \frac{1}{n!}(-1)^n(0.5)^n[/tex]<br /> [tex]= \sum_{n=0}^\infty \frac{(-1)^n}{n!}(0.5)^n[/tex]<br /> <br /> They are exactly the same.[/tex][/tex][/tex]
