Is it just the HD that slows the computer down as it gets older?
  • Thread starter Thread starter Simfish
    Computer
The discussion revolves around the factors contributing to a computer's slowdown as it ages, particularly focusing on the role of the hard drive, software changes, and other hardware components over a span of 7-10 years. Participants explore various hypotheses regarding performance degradation, maintenance, and potential solutions.
  • One participant suggests that replacing the hard drive might restore performance, questioning the significance of mechanical wear over time.
  • Another participant argues that age itself does not slow down computers, attributing perceived slowness to increased software demands and accumulated background processes.
  • A third participant proposes that reinstalling the original operating system and software could return the computer to its original speed, assuming no hardware failures.
  • It is noted that processor speed and RAM are critical factors in computer performance, with insufficient RAM leading to excessive hard drive usage as virtual memory, which can slow down the system.
  • A practical example is provided where a friend's computer was slowed down due to high hard drive usage as virtual cache, which was resolved by disabling this feature.
  • Concerns are raised about resource-heavy applications, particularly browser extensions, which can consume significant memory and affect overall performance.
Participants express differing views on the causes of computer slowdown, with some attributing it to software and usage patterns while others consider hardware factors like the hard drive and RAM. No consensus is reached on the primary cause of performance degradation.
Participants mention various assumptions, such as the condition of hardware components and the impact of software updates, without resolving the implications of these factors on performance. The discussion also highlights the complexity of diagnosing performance issues.
Simfish
Or will my computer be just as good as new if I, say, replace the hard drive with a new one?
Sure there's dust build-up in the processor, but its effects are related to heat buildup and I found an alternative way of cooling my PC CPU down to levels it may not have seen even when I got it.
It has other mechanical components that wear down too, but are those effects significant over the space of 7-10 years?
Computer science news on Phys.org
Nothing wears out or slows down with age - two things happen.
New software does more, especially little GUI ricks that take more proessing power and so make it seem slower.
You build up a collection of crud, little task bar apps that are constantly running that you don't use anymore
Assuming nothing is actually broken: If you reinstall your original operating system and software, and don't get the latest and greatest version of everything, then it should run just as fast as when you first purchased it.
The speed of your computer is mainly affected by your processor speed, RAM and the needs of your applications. Of course with processors, faster is better. Increasing the amount of RAM is often a good quick fix to speed up your computer. If you are hearing your hard drive running all of the time, it is possible that you don't have enough RAM and Windows has decided to use your hard drive as a virtual cache. The hard drive is much slower for this task and it's very hard on it as well.
I recently fixed a friend's computer that was using over a Gig of his hard drive as part of his cache. His computer was a year-old dual core and should have been very fast. When it first started, it was fine. But, within a half hour, it would get slower and the hard drive was running constantly. We turned off the virtual cache, the hard drive stopped going beserk and everything was fine.
If the slowness of your computer isn't the RAM, then the next step is to see what is running on your computer. Many common apps like browser toolbars and other addons can be terrible resource hogs. I use a Firefox addon called Firebug for my development work but sometimes I have to restart Firefox because it's using too much memory. I've caught the browser using over a Gig of memory on several occasions (1.6 Gig was the record when it crashed :eek:).
  • · Replies 30 ·
  • · Replies 43 ·
