Verification of moment of inertia calculation
The discussion centers on the calculation of the moment of inertia for regular polygons, specifically the formula I = (m/6)(3+tan(pi/n)^2)*R^2, where m is the mass, n is the number of edges, and R is the distance from the center to an edge. The user seeks verification of this formula against known values, noting discrepancies when comparing it to the moment of inertia for a square and a thin solid disc. The conversation highlights the importance of clarifying the axis of rotation, as it affects the moment of inertia results.
  • Understanding of moment of inertia concepts
  • Familiarity with regular polygon geometry
  • Knowledge of trigonometric functions, specifically tangent
  • Basic principles of rotational dynamics
  • Verify the moment of inertia for various regular polygons using the provided formula
  • Explore the derivation of moment of inertia for a thin solid disc
  • Study the impact of axis of rotation on moment of inertia calculations
  • Research advanced applications of moment of inertia in engineering contexts
Students and professionals in physics, mechanical engineering, and mathematics who are interested in understanding and applying moment of inertia calculations for various geometric shapes.
Yaridovich
I was looking at the moment of inertia list that they have on Wikipedia and noticed that the moment of inertia for a regular polygon was rather complicated. I did the calculation myself and found a significantly simpler result of
I = (m/6)(3+tan(pi/n)^2)*R^2:
m is the mass of the polygon,
n is the number of edges of the polygon,
R is the length of the line segment from the center of the polygon to one of its edges, where the line segment is perpendicular to that edge. I just wanted to verify that this is correct; I can submit a proof of how I calculated this if need be.
How about testing it out first for a few known polygons.If n is infinity you will have a thin solid disc for which the MI=(mR^2)/4.I think your equation gives (mR^2)/2
Whoops,we need to clarify this.If the axis of rotation is through the centre and at 90 degrees to the plane of the disc then the MI=(mR^2)/2.If you are considering the same axis then your equation seems to give the right answer.Try some other polygons.
moment of inertia of square:
[tex]I_c=\frac{m(h^2+w^2)}{12}=\frac{m(2h^2)}{12}=\frac{m(\sqrt{2}R)^2}{6}=\frac{mR^2}{3}[/tex]
but your formula shows:
[tex]I_c=\frac{2mR^2}{3}[/tex]
  • · Replies 49 ·
  • · Replies 30 ·
  • · Replies 69 ·
  • · Replies 138 ·
10K
