 Quote by alxm
Well I was thinking if you specifically generate triplet helium and then ..
That was my other main concern: By what method would you
"specifically generate triplet helium"??(not BEC)
This is a 'forbidden' transition; It can only occur (in an isolated atom) due to two-photon processes, which one can think of as a decay to a 'virtual' level in-between the two states. For Helium it's not symmetric; one of the photons carries more energy than the other, so you end up with two peaks, one at ~70 nm and one at ~2400. (See e.g. this paper, if you want some details)
Thanks for the G W Drake link. I'm not too sure I understand it all....Of course, Selection rules prohibit single photon transitiion .... so it goes two photon route...OK, but this rate is extremely low, right?
I have read elsewhere that the most probable decay is thru 'collisional' process, I am not sure what that refers to ...any info there?
GW Drake has a later article in which it appears as if he is saying that there is a MORE probable Magnetic dipole transition to ground state decay...am I reading that right?
See here:
http://cos.cumt.edu.cn/jpkc/dxwl/zl/...atomic/099.pdf
Creator
