Help with prime factorization proof
The discussion revolves around a proof concerning prime factorization, specifically addressing the statement that if the product of two integers \( ab \) is divisible by a prime \( p \), and one of those integers \( a \) is not divisible by \( p \), then the other integer \( b \) must be divisible by \( p \). Participants explore the implications of the greatest common divisor and the use of integer combinations in the proof process.
  • One participant expresses uncertainty about the meaning of \( (a,p)=1 \) and seeks clarification on its implications for the proof.
  • Another participant explains that \( (a,p)=1 \) indicates that the greatest common divisor of \( a \) and \( p \) is 1.
  • A participant suggests that since \( ab \) has a factor \( p \) and \( a \) does not, it logically follows that \( b \) must have the factor \( p \).
  • Another participant introduces a more complex example involving the integers \( \sqrt{5} \) and discusses the implications of prime factorization in different number systems.
  • One participant attempts to clarify the proof by stating that since \( p \) divides \( tpb \) and \( sab \), it follows that \( p \) divides \( b \), but this reasoning is not universally accepted.
  • Several participants engage in a light-hearted exchange about the relevance of older threads and the nature of the discussion.
  • There is a suggestion that the initial statement may not be true, but it is unclear what specific aspect is being questioned.
Participants express a mix of agreement and disagreement regarding the proof and its implications. While some support the logical reasoning behind the proof, others raise questions about its validity and the assumptions involved.
Some participants reference the need for clarity on the division algorithm and its applicability in different mathematical contexts, indicating that the discussion may be limited by assumptions about the number systems being considered.
Ed Quanta
I have to prove that if ab is divisible by the prime p, and a is not divisible by p, then b is divisible by p.
In order to prove this, I have to show (a,p)=1. I am not sure what this statement means.
Then I am supposed to use the fact that 1=sa + tp when s,t are elements of the set of integers. (This statement was already proved in class). Then I figured to multiply across by b so that we get
b= sab + tpb. I am not sure where to from here. I have not seen to many proofs regarding prime factorization. Thanks
Ed
(a,p)=1
This means "The greatest common divisor of a and p is 1". You may have sometimes seen this written as gcd(a, p) = 1.
b= sab + tpb
Well, you want to know if p divides the LHS of this, and the LHS is equal to the RHS...
Ed
If ab has a factor p and a don't, then b has the factor. That's logic.
If a = c + id and b = e - id, it's a bit harder.
Every result in maths is 'just logic', surely.
To show there is some content, consider Z{sqrt(5)]
2 is prime
2 divides 4=(sqrt5 - 1)(sqrt 5 +1)
2 divides neither of the terms on the left as they are both prime too.
so it important that the division algorithm works in Z. Or was that reference to x+iy some indiction of something in the ring Z?
You are almost finished.
Ed
Since you have already arrived at b=sab +tpb, we know that p divides tpb, and p divides sab so that p divides b.
If there seems a need here for steps, we can look at p(sab/p +tb) =b. Since we know (sab/p +tb) is an integer, we see that b contains the factor p.
Do you enjoy necromancing threads that are months old or something? :P
Perhaps it's not true?
I hoped I wasn't doing any harm. As for as good, well, I don't know. I thought it added for completeness.
Oh no, I was just kidding around when I said that.
Perhaps WHAT'S not true?
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 17 ·
  • · Replies 21 ·
