Oil shortens lifespan of halogen bulbs?
  • Context: High School
  • Thread starter Thread starter DaveC426913
    Oil
The discussion revolves around the impact of oil from hands on the lifespan of halogen bulbs, particularly in projectors and automotive applications. Participants explore whether handling bulbs can lead to overheating and potential failure due to oil contamination.
  • One participant recalls being taught that oil from hands can cause overheating and shorten the lifespan of halogen bulbs.
  • Another participant assumes that an oil film on the bulb glass could absorb heat, potentially leading to cracking.
  • Concerns are raised about oil creating darker spots on the lens, which might retain more heat.
  • A participant notes that while quartz projection lamps can fail explosively due to surface contaminants, quartz halogen lamps, although running cooler, can still be damaged.
  • One participant asserts that the advice against touching halogen bulbs is valid, referencing automotive applications where stores refuse returns on touched bulbs. They mention the possibility of cleaning the glass with alcohol to mitigate issues.
  • Another participant humorously comments on the terminology used to describe bulb failures.
Participants express varying opinions on the validity of the claim that oil affects halogen bulb lifespan, with some supporting the idea and others questioning it. No consensus is reached on the overall impact of oil contamination.
Participants mention different types of bulbs and their operating conditions, but there are unresolved assumptions regarding the specific mechanisms by which oil may affect bulb performance.
DaveC426913
2025 Award
A brazillion years ago, I was taught not to handle the bulbs used in projectors under the rationale that the oil from your hands ends up on the bulb, causing overheating and shortening the lifespan of the bulb.
I've generalized this to other hot bulbs such as the little 10, 20 and 50W halogens in common use.
It occurs to me that this may not be valid.
Thoughts?
Yes, I've heard this too. I assume, without knowledge, that an oil film on the bulb glass absorbs and retains a great deal of heat; perhaps enough to eventually crack the bulb.
It's an issue if the oil creates a darker and/or less transparent spot on the lens, which could then cause more heat to be retained.
Projection lamps are high temperature arc lamps made of quartz. Surface contaminants can initiate devitrification of the quartz lamp envelope leading to an explosive lamp failure.
Quartz halogen lamps run cooler but can still be damaged. A typical operating temperature for an arc lamp might be 800 C.
It is definitely valid. Halogens are used as standard in most Autos’. The auto parts stores tell you not to touch the glass, and will not replace them if you return a few hours later with a bulged out bulb.
However if you do accidentally touch them you can wipe the glass with alcohol and dry. Other people say it is the salt that causes the problem.
For a description see 03) Halogen Technology here:
http://www.8thcivic.com/forums/lighting/153822-primer-light-bulb-technologies.html
I love it. "experiences non-passive failure" instead of "explodes"
  • · Replies 19 ·
  • · Replies 133 ·
29K
  • · Replies 152 ·
12K
