Electromagnetic Motor (Simple Motor) & Voltmeters
The discussion revolves around an experiment involving simple electric motors and the challenges encountered when integrating a voltmeter into the circuit. The original poster is investigating why the motor fails to operate correctly when the voltmeter is added, suspecting that the voltmeter's resistance may be affecting the current.
  • Participants inquire about the configuration of the voltmeter in relation to the motor, the type of motor used, and the power supply characteristics. There are discussions about the potential impact of the voltmeter's resistance and suggestions to connect it in parallel with the motor.
The conversation is ongoing, with participants exploring various configurations and questioning the assumptions about the voltmeter's effect on the motor's operation. Some guidance has been offered regarding the wiring of the voltmeter, but no consensus has been reached on the underlying issue.
There is mention of the motor's susceptibility to interference and the specific design of the armature, which may affect the accuracy of voltage readings when the voltmeter is connected in parallel. The original poster also notes uncertainty regarding the resistance of the load.
Dazz4C
Hi Everyone,
So I'm currently doing a small experiment on Simple Electric Motors. I've only encountered one problem so far, and that is the when I add a volt meter to the circuit to measure the input voltage to the motor, the motor doesn't want to seem to work. Can't seem to think of why that would be...unless the voltmeter has resistance, altering the current.
Would anyone care to think of why this would be?...other than the volt meter adding resistance.
Is the voltmeter installed in parallel with the motor? What type of motor is it? It would help if you could MSPAINT out a quick schematic.
The motor is something like this:
http://www.sciencebuddies.org/science-fair-projects/project_ideas/Elec_p009.shtml
and here's the 2 second schematic.
Okay, well the first thing that comes to mind is that you might not have enough power to run the motor with the voltmeter installed. Is it a digital multimeter type device? Or is it just a voltgauge with no power source of it's own?
You might try placing the meter in parallel with the load(motor) like this..
Additionally, do you know the voltage of your power supply, resistance of the load etc?
I've used both a digital an analogue voltmeter, both have the same results (can't start the motor). I'll try putting it parallel with the motor...and also, I do know the voltage but need the voltmeter for verification; I also don't know the resistance of the load.
EDIT: When I put the volt meter parallel, it stops it from spinning...so doesn't look like it worked. Pretty strange.
That's pretty strange indeed. A voltmeter wired in parallel to the load of a circuit should have no (well, barely any) impact on it's operation provided the voltmeter is self-powered.
I took a closer look at the article you posted on the little motor, it looks like it would be very susceptible to interference. Are you sure that the brushes are making contact in the circuit?? It does work without the voltmeter correct?
The brushes are making contact with the circuit. But the thing is, if I put it in parallel to the motor, the input voltage won't be accurate...because the armature on the coil has half the insulation scraped off for the coil to discharge after half a rotation, allowing more force to turn the motor on the next rotation.
That's why I wanted it to be connected in series.
10K
  • · Replies 31 ·
  • · Replies 25 ·
  • · Replies 41 ·
