Rocket equation exhaust velocity question
The discussion centers on the rocket equation, specifically how a rocket can achieve the necessary orbital velocity of 7.8 km/s with an exhaust velocity of only 4.4 km/s. It explains that the mass of the fuel must be significantly greater than the mass of the rocket itself, calculated to be about 4.87 times the rocket's mass, to satisfy conservation of momentum. During the initial seconds of launch, the rocket must burn a small fraction of its total mass to overcome gravity, which is about 0.0022 of the ship's mass. The rocket equation accounts for the mass of unused fuel and the varying speeds of the exhaust, allowing the rocket to reach the desired velocity despite the lower exhaust velocity. Overall, the mechanics of rocket propulsion and mass ratios are crucial for understanding how rockets achieve their velocities.
randomking333
The rocket equation given by Delta V = Ve ln (Mo/M) says that Ve is the exhaust velocity of the rocket.
The orbital velocity for Low Earth Orbit is about 7.8 Km/s. How then, is this velocity attained by a rocket which is fuelled only by a bipropellant rocket engine producing an exhaust velocity of 4.4 Km/s. Using conservation of momentum, the heavier mass of the rocket won't reach the velocity of the exhaust?
Pls explain to me how this works..
THanks in advance
In The rocket equation, Mo would be the Mass of ship+fuel and M would be the mass of the ship alone.
Given that, we can solve for the fuel mass by:
e^{\frac{\Delta V}{V_e}}= \frac{M_s+M_f}{M_s}
e^{\frac{\Delta V}{V_e}}= \frac{M_f}{M_s}+1
M_s e^{\frac{\Delta V}{V_e}}-1= M_f
With the given final velocity and escape velocity, this gives a fuel mass of 4.87 times that of the mass of the ship alone. So the mass of the fuel is far greater than the mass of the rocket, and there is no problem with conservation of momentum.
Mass of the stage of the rocket that reaches orbital velocity is far, far smaller than total mass of the propellant. If you were simply applying a conservation of momentum, you'd end up with final speeds well above orbital. The reason you get only 7.8km/s is that propellant ends up traveling at speeds varying from -4.4km/s to +3.4km/s. The rocket formula you quoted is a result of adding up momenta of all these contributions in correct proportions.
Yes.. but for any point in time taken.. say a span of 1 second early in the launch...
mv=mv
so the pass of the rocket at that time is much greater.. since the exhaust velocity is of the fuel being burned per unit time?.. so that mass of fuel is a lot less? .. or are we meant to consider even the fuel that is still in the chamber and not burnt (and hence not at that exhaust velocity)
Thanks in advance
mv=mv
Thanks in advance
Let's take the first second of launch. First you have to overcome the force of gravity which is the equivalent of 9.8m/s². Which means that it is the same as accelerating to 9.8 m/s in one second. Using the rocket equation we find that it would take 2.2e-3 times the remaining mass of the ship to do this.( In this case, Mo is equal to the mass of the rocket plus the un-used fuel on board)
IOW, with an exhaust velocity of 4.4 km/s, If you burn about 2 one-thousandths of the ships total mass in the first second, you will overcome gravity. Anything over that will accelerate the ship upward.
In terms of momentum, if MV is the final momentum of the ship and mv is the momentum of the exhausted fuel, then at a v of 4400 m/s, at V of 9.8m/s:
9.8M= 4400m
m/M = 9.8/4400 = 0.0022
Which again gives an answer of about 2/1000 of the ships total mass needed to be burned in one second to overcome gravity.
If you carry out the above solutions to a few more decimal places you will find that the rocket equation gives a slightly larger value. This is because it factors in the fact that during the first part of the second, the rocket has to still lift the fuel it will burn later in the sec. That is the point of using the rocket equation, it takes into account the mass of the remaining unused fuel.
Although the terminal exhaust velocity relative to the rocket is fixed, that exhaust accelerates both the rocket and the remaining on board fuel, so that as the rockets and on board fuel increases speed, so does the exhaust velocity (with repect to the initial velocity of the rocket).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
