Calculating alkalinity and expressing it in as CaCO3
  • Thread starter Thread starter Jim4592
This discussion focuses on calculating alkalinity expressed as CaCO3 from various ions, specifically Ca2+, Mg2+, CO2, HCO3-, and CO32-. The calculations provided by the user yield results that are slightly different from the textbook answers due to variations in molar masses used. For instance, the calculated value for Ca2+ is 207.096 mg/L as CaCO3, while the book states 207.25 mg/L. The differences in results are acknowledged to be negligible, indicating that the user's calculations are fundamentally correct.
  • Understanding of chemical molar mass calculations
  • Knowledge of milliequivalents (meq) and their application in chemistry
  • Familiarity with the concept of alkalinity in water chemistry
  • Basic proficiency in unit conversion for chemical concentrations
  • Research the impact of molar mass variations on chemical calculations
  • Learn about the significance of alkalinity in environmental science
  • Explore the use of titration methods for measuring alkalinity
  • Study the relationship between alkalinity and pH in aquatic systems
Chemistry students, environmental scientists, water quality analysts, and anyone involved in water treatment processes will benefit from this discussion.
Jim4592
Calculating alkalinity and expressing it in "as CaCO3"
Convert the following from milligrams per liter as the ion to milligrams per liter as CaCO3.
A) 83.00 mg/L Ca2+
B) 27.00 mg/L Mg2+
C) 48.00 mg/L CO2
D) 220.00 mg/L HCO3-
E) 15.00 mg/L CO32-
I think I did the calculations correctly, but there's a slight difference between my answer and the book's answer...I was hoping someone could look and see if I did the steps correctly and if so is it difference negligible?
A) (83.00 mg Ca{2+} / L) x (1 mmole Ca{2+} / 40.078 g) x (2 meq Ca{2+} / mmole Ca{2+}) x (100 mg CaCO3 / 2 meq) = 207.096 mg/L as CaCO3, book answer = 207.25
B) (27.00 mg Mg{2+} / L) x (1 mole Mg{2+} / 24.305 g) x (2 meq Mg{2+} / mmole Mg{2+}) x (100 mg CaCO3 / 2 meq) = 111.088 mg/L as CaCO3, book answer = 111.20
C) (48.00 mg CO2 / L) x (1 mmole CO2 / 44.0095 g) x (2 meq CO2 / 1 mmole) x (100 mg CaCO3 / 2 meq) = 109.067 mg/L as CaCO3, book answer = 109.18
D) (220 mg HCO3{-} / L) x (1 mmole HCO3{-} / 61.01684 g) x (1 meq / 1 mmole) x (100 mg CaCO3 / 2 meq) = 180.278 mg/L as CaCO3, book answer = 180.41
E) (15.00 mg CO3 / L) x (1 mmole CO3 / 60.0089 g) x (2 meq / 1 mmole) x (100 mg CaCO3 / 2 meq) = 24.996 mg/L as CaCO3, book answer = 25.02
Obviously book uses slightly different molar masses. I wouldn't care too much, differences are below 10-3, that's about as precise as you can determine alkalinity experimentally.
alright thank's borek, I thought I would be able to just write it off but that's the farthest off we've ever been, so I figured I'd ask for a second opinion.
15K
15K
40K
