Sorting Fresh & Boiled Eggs with an Inclined Plane
The discussion focuses on the design of an automatic egg sorter utilizing an inclined plane to differentiate between fresh and hard-boiled eggs. The proposed method relies on the conservation of energy equation, specifically mgh = 1/2mv², while accounting for friction losses between the egg shell and the inclined plane. Key insights include the differences in mass and momentum between fresh and boiled eggs, which affect their movement on the incline. Participants also suggest alternative methods for testing egg types, such as spinning eggs to observe their rotational behavior.
  • Understanding of conservation of energy principles
  • Knowledge of friction coefficients for various materials
  • Basic physics of rotational motion
  • Familiarity with inclined plane mechanics
  • Research the coefficient of friction between egg shells and aluminum surfaces
  • Explore advanced concepts in rotational dynamics and inertia
  • Investigate automated sorting mechanisms for different object types
  • Learn about energy loss calculations in mechanical systems
Physics students, mechanical engineers, and anyone interested in automating sorting processes using physical principles.
no183
here i am going to sort out fresh and hard boil egg. i suggested that used incline plane. It is expected that the boil egg will pass through the second positive gradient incline while the fresh egg are not.
so my question is, what the equation involve.
my first equation i apply is the conservation of energy equation
mgh=1/2mv square - (friction loss between the egg shell and inclide plane (aluminium sheet))
is my equation correct?
what the coefficient of egg shell and incline plane?
on my research, i found out that fresh and boil egg are different in their mass(slightly). as a result the momentum is different in the egg right? so in the conservation of energy equation, what term should be constant and what not? velocity or mass is constant?
is there anything else to improve the experiment?
there's friction between the shell and the inside, and kinetic energy will be lost while the inside slowly starts rotating. I wouldn't try to calculate this.
A simpler way to test an egg is to try to rotate it on a table. You can flick a hard boiled egg once with two fingers, and it will keep spinning for a long time. A fresh egg will almost completely come to a stop if you do this.
Another way is to keep the egg rotating for a while (spinning or rolling), then bring it to a sudden stop by hand and then release it. A fresh egg will start to rotate again.
yes agree, the method u mention already tried. it is due to the inertia, but that is by manual method. but now i need is apply this phenomena in the auto egg sorter which use incline.
any idea?
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 19 ·
