The Mystery of Why Photons Have No Mass
  • Context: Graduate
  • Thread starter Thread starter Waveparticle
    Mass Mystery Photons
The discussion centers around the question of why photons do not have mass, particularly in relation to the Higgs field and its role in particle mass generation. Participants explore theoretical frameworks, including the Higgs mechanism, gauge symmetries, and the implications for other particles such as gluons and gravitons. The conversation includes technical explanations and conceptual clarifications regarding the Standard Model of particle physics.
  • Some participants propose that the lack of mass for photons is due to their non-coupling with the Higgs field, specifically in the context of spontaneous symmetry breaking of SU(2) x U(1).
  • Others argue that the Higgs field interacts with both SU(2) and U(1) but leaves one superposition of the gauge bosons massless, which corresponds to the electromagnetic U(1) symmetry.
  • A later reply questions whether similar reasoning applies to gluons and gravitons, with some uncertainty expressed about gravitons.
  • Participants discuss the subtlety of fermion masses and the necessity of coupling constants in relation to the Higgs field, noting that introducing mass terms directly would violate gauge symmetry.
  • Some contributions highlight that there are Higgs-less models for mass generation, though these may not account for all types of mass.
  • There is a discussion about the energy of fermions and how it relates to mass, with references to the relativistic energy-momentum relation.
  • One participant critiques common misconceptions regarding the breaking of gauge symmetry in the context of the Higgs mechanism, suggesting that local symmetries cannot be spontaneously broken.
Participants express multiple competing views regarding the role of the Higgs field and gauge symmetries in mass generation, indicating that the discussion remains unresolved with no consensus reached.
Limitations include varying interpretations of gauge symmetry breaking, the dependence on specific models, and the unresolved status of Higgs-less theories in accounting for all particle masses.
Waveparticle
Why doesn't the Higgs field give photons mass?
It has to do with the spontaneous symmetry breaking of [tex]SU(2) x U(1)[/tex], the photon essentially doesn't couple to the Higgs Field.
"The simplest implementation of the mechanism adds an extra Higgs field to the gauge theory. The spontaneous symmetry breaking of a local symmetry causes this Higgs field to interact with (at least some of) the other fields in the theory, in a manner producing mass terms for (at least some of) the gauge bosons. The symmetry breaking can also produce elementary scalar (spin-0) particles, known as Higgs bosons." - Wikipedia
b/c it is constructed such that it couples to the SU(2) triplet, not to the U(1) gauge field
Is this same answer used for gluons and gravitons.
Yea, I'm not sure about gravitons though.
The Higgs is constructed explicitly to generate a mass for the W and the Z and to leave to photon massless. b/c one does not believe that gluons have mass, one does not introduce a Higgs in the SU(3) sector.
This is not correct. The U(1) force in the standard model's SU(3)xSU(2)xU(1) couples to hypercharge, not to electric charge. The Higgs couples to both SU(2) and to U(1). However, it necessarily leaves one superposition of the U(1) and SU(2) gauge bosons massless, indicating a residual, unbroken U(1) symmetry, which is the U(1) of EM.
it simply depends if you talk about U(1) and SU(2) before symmetry breaking and rotation or after; there is no coupling of the Higgs vev to the photon which is the physical U(1) EM gauge boson; that's why the photon remains massless.
So my sentence should read ... b/c it is constructed such that it couples to the physical SU(2) triplet (W, Z), not to the physical U(1) EM gauge field
is the Higgs field necessarily associated with the Higgs boson and does it give mass to EVERY fermion?
The Higgs boson is the oscillation of the Higgs field around its vacuum. Its like any other quantum field and the corresponding relation between field and particle in QFR - excpet for the fact that its vev is nonzero.
The fermion masses are subtle. Usually one is allowed to introduce standard mass terms. But due to the chiral structure of the electro-weak interaction this would violate a local gauge symmetry and one must therefore find a new mechanism to introduce these masses.
Again this is ad-hoc: instead of introducing a mass mf for each fermion f one introduces a coupling constant gf which couples the fermion to the Higgs. The mass is related to gf and to the vev of the Higgs. So the arbitrary masses are replaced by arbitrary coupling constants (ugly!). If there are massless fermions on is allowed to set this coupling to zero.
but what about the energy instead of the mass? for example neutrinos have a very small mass but move at relativistic speeds, so more energy than mass. is the higgs boson responsible for all that energy then? where does the energy of fermions come from?
The fermion energy is
E² = (mc²)² + (cp)²
where m is generated via the Higgs vev and p is the usual kinematical momentum and has nothing to do with the Higgs.
So once the rest mass m is created via the Higgs vev, everything remains unchainged.
ok, thank you. but how likely can the Higgs be found? and what happens if there is no higgs, where does the mass come from?
Ask the LHC guys :-)
There are Higgs-less models for mass creation, but most people today do believe in the Higgs.
See e.g.
http://arxiv.org/abs/0905.3187
Unanswered Questions in the Electroweak Theory
Authors: Chris Quigg
(Submitted on 19 May 2009 (v1), last revised 7 Jul 2009 (this version, v2))
Abstract: This article is devoted to the status of the electroweak theory on the eve of experimentation at CERN's Large Hadron Collider. A compact summary of the logic and structure of the electroweak theory precedes an examination of what experimental tests have established so far. The outstanding unconfirmed prediction of the electroweak theory is the existence of the Higgs boson, a weakly interacting spin-zero particle that is the agent of electroweak symmetry breaking, the giver of mass to the weak gauge bosons, the quarks, and the leptons. General arguments imply that the Higgs boson or other new physics is required on the TeV energy scale. Indirect constraints from global analyses of electroweak measurements suggest that the mass of the standard-model Higgs boson is less than 200 GeV. Once its mass is assumed, the properties of the Higgs boson follow from the electroweak theory, and these inform the search for the Higgs boson. Alternative mechanisms for electroweak symmetry breaking are reviewed, and the importance of electroweak symmetry breaking is illuminated by considering a world without a specific mechanism to hide the electroweak symmetry.
For all its triumphs, the electroweak theory has many shortcomings. . . .
I would add to this that there are possible mechanisms for the generation of neutrino mass (such as the type 2 see-saw) that don't at all involve the standard model Higgs. In fact, any model that doesn't add new standard model-singlet fermions in the process of generating neutrino mass will necessarily not involve the SM Higgs.
Yes, this is one example of a Higgs-less model, but afaik it does not account for all masses but only for special particles.
Just a comment to the wikipedia quote. I think that it is a common misconception (because of sloppy treatment/terminology in most books ) that the gauge symmetry is spontaneously broken in the Higgs mechanism. The gauge symmetry is not a physical symmetry, but redundancy in our description and therefore it makes no physical sense to break this "symmetry". Even if we had some local symmetry, the famous http://prd.aps.org/abstract/PRD/v12/i12/p3978_1" says that you cannot (spontaneously) break local symmetries!
One first need to explicitly (by hand) break the local gauge symmetry, and the residual physical global symmetry can then be spontaneously broken.
For a discussion of these issues in the case of Abelian gauge theory (superconductor oriented) see http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6WB1-4G6J89R-1&_user=2149863&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000056383&_version=1&_urlVersion=0&_userid=2149863&md5=26858acdc59c7e515e3509f1c9e44a30").
I never claimed the type-2 see-saw was a Higgsless model for EWSB. It's a Higgsless model of neutrino mass. I was specifically adding this as a caveat to you're post's implication that the Higgs field is responsible for all fermion masses. In the case of the neutrino (even presuming the existence of an ordinary standard model Higgs), it is simply unknown.
agreed
the photon does not react with the higgs field in the same way (or not at all )that over particles do, so it has not mass
  • · Replies 17 ·
